05-02-2014, 06:43 PM | #1 |
Is there a way
Wondering if there is a way to take out the tail light buckets from inside the bed without cutting up the bed itself. Is it possible or not?
05-02-2014, 07:00 PM | #2 |
Re: Is there a way
Not sure I understand the question. The tail light buckets come out on the outside.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
05-02-2014, 07:46 PM | #3 |
Lurky lurky
Re: Is there a way
I did it less than a week ago and just took the two screws out of the plate and pulled them through the cut out in the bed side. It was a tight fit but tape on the bodywork and a little prying with a pocket screwdriver and they were out.
05-02-2014, 10:17 PM | #4 | |
Re: Is there a way
Thanks. I'll have to check mine out. |
05-03-2014, 12:30 AM | #5 |
Lurky lurky
Re: Is there a way
I should be able to post pics early next week if you don't get it before then. It's all apart right now.
05-03-2014, 05:09 PM | #6 |
Re: Is there a way
05-03-2014, 05:19 PM | #7 |
Re: Is there a way
Ya the buckets come out there just screwed in undo the screws and they pop right out
05-03-2014, 05:22 PM | #8 |
Re: Is there a way
I took mine out so I could weld over the chrome strip holes so I didn't have to have the chrome around the lights
05-10-2014, 08:21 PM | #9 |
Lurky lurky
Re: Is there a way
Sorry it took me a week, the truck is at my dad's house.
Take out the two screws in the housing out, then I gently pried on the bottom and pulled it out at an angle. Then I had enough room to get my fingers under the bottom of it It comes out, just barely in the cut out for it Then I unplugged the wiring to the bulb. End result. Hope that clears it up for you... |
