Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-31-2020, 03:52 AM   #1
Grizz1963
Grizz1963's Avatar
Build sheet readers - anyone clever with them?
So I bought this truck.
Happy so far, 90 miles later
Any build code readers on here?
What have I bought here?
Thanks.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is online now   Reply With Quote
Old 12-31-2020, 07:45 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Build sheet readers - anyone clever with them?
Hope this helps you out,RPO Code List
AA3 Windows: Deep Tint 1/4 Window; Light Tint Rear Window
AG0 Seat Adjuster: Power/Memory, Eight-Way, Two-Position, Driver
AG1 Seat Adjuster: Power, Six-Way, Driver
AG2 Seat Adjuster: Power, Six-Way, Passenger
AH8 Seat Adjuster: Power, Eight-Way, Passenger
AJ1 Windows: Deep Tint, all Except W/S and DRS
AM6 Seat: Front Split, 3 Passenger, Center Armrest
AM7 Seat: Rear Folding
ANL Sales Package: Air Deflector and Fog Lamps
AN3 Seat: Driver, Pass, Elect. Body Support
AP9 Convenience Net
AU0 Lock Control, Remote Entry
AU3 Lock Control, Side Door, Electric
AV5 Seat: Front Bucket, High Back
AXP Vin Ident Position, Multi-Purpose Vehicle, Requires AM7 Rear Seat
AX4 Restraint Conversion Seat, Man, European
A26 Window, European Glazing, All
A28 Window: Sliding Rear, Full Width
A31 Window: Power Operated, Side
A52 Seat: Front Bench
BAG Parts Package Export
BG9 Covering: Floor, Rubber
BNB Ornamentation, Exterior, Unpainted, Export
B30 Covering: Floor, Carpet
B32 Covering: Front Floor Mats, Aux
B84 Molding: B/S Exterior
B94 Appearance Package: Bravada, Gold Package Content
CE4 Washer, Headlamp, High Pressure, Export
CF5 Root, Sun, Glass, Sliding Electric
CKD Vehicle knocked Down
CR0 Lamp Interior, Eng Compt, Courtesy - Delete
CTB Appearance Package: Chevrolet Trailblazer Sport
C25 Wiper System: Rear Window, Intermittent
C3A 4400 Lbs. GVW Rating
C3G 4450 Lbs. GVW Rating
C3T 5350 Lbs. GVW Rating
C42 HVAC System: Heater, Deluxe, Outside Air
C49 Defogger, Rear Window, Electric
C5A 4900 Lbs. GVW Rating
C5C 5000 Lbs. GVW Rating
C5D 4600 Lbs. GVW Rating
C5T 4200 Lbs. GVW Rating
C5X 4650 Lbs. GVW Rating
C6F 5150 Lbs. GVW Rating
C61 4850 Lbs. GVW Rating
C60 HVAC System: Air Conditioner, Front, Manual Controls
C88 HVAC System: Air Conditioner: Front, Automatic, Electronic Controls
DD0 Mirror: O/S, LH & RH, Rem. Control, Heated, LH LT Sensitive, Color
DH6 Mirror: I/S, Sunshade, Ilium., LH & RH
DK2 Mirror: O/S, LH & RH, Rem. Control, Electric, Heated, Color
DK7 Console: Roof, Interior, Custom
DK8 Console: Roof, Interior, Deluxe
DR4 Mirror: O/S, LH & RH, Rem. Control, Heated, Electric, Dual Pwr. Folding, LT Sensitive, Color
D07 Console: Front Compartment Floor, Custom
D34 Mirror: Inside, Sunshade
D44 Mirror: O/S, LH & RH, Man. Control, Color
D55 Console: Front Compartment Floor
D88 Stripe: Decal, Sport
D96 Stripe: Body Side, Upper
EXP Export, I.E.S.
E09 Equipment, Country, Europe
E24 Door: Side Cargo, Hinged
E55 Body Equipment: End Gate
E62 Body Equipment: Stepside, PUBX
E63 Pickup Box: Fleetside, PUBX
FE9 Certification: Emission, Federal
F46 Chassis: All Wheel Drive
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G67 Level Control: Automatic, Air
G80 Rear Axle: Positraction, Limited Slip
JC1 Brake: Vac. Power, 4 Whl Disc, 5500 Lbs.
JM3 Brake Booster: 260 MM, Tandem High Flow
KA1 Heater: Seat
K05 Heater: Engine Block
K18 Reactor System Air Injection, Electric
K34 Cruise Control: Automatic, Electronic
K42 Air Cleaner "Off Road" Package
K53 Fuel Sender Asm, Robust Fuel System
K55 Fuel Sender Asm, Low Lubricity
K60 Generator: 100 Amp
LF6 Engine: Gas, 6 Cyl, 4.3L, CPI, V6, 90 Deg.
LN2 Engine: Gas, 4 Cyl, 2.2L, MFI
L35 Engine: Gas, 6 Cyl, 4.3L, CPI, V6, 90 Deg, HO
MW2 Transmission: Manual 5 Speed, New Venture Gear, 76mm, 3.94 1st
M30 Transmission: Auto 4 Speed, 4L60-E, Electronic
M50 Transmission, Manual 5-Speed, NVG, 85 mm, 3.49 1st, O/D
NA7 Emission System, European
NB7 Emission System: California, TLEV
NB8 Emission Override, California System
NC1 Emission System: California, LEV
NC7 Emission Override, Federal System
NF2 Emission System: Federal, Tier 1
NG1 Certification Emission, Geographically Restricted Registration
NM8 Leaded Fuel System Compatible
NN8 Emission Override, Unleaded Fuel, Export
NP1 Transfer Case: Electrical Shift, Two Speed
NP4 Transfer Case: Active 4WD, All Wheel Drive (AWD)
NP5 Steering Wheel: Leather Wrapped
NP6 Provisions, Transfer Case, Export
NP8 Transfer Case: Active, Two-Speed, Push button Control
N12 Exhaust System, Rear Exit
N33 Steering Column: Tilt Type
N40 Steering: Power, Non-Variable Ratio
N60 Wheel: Aluminum, Painted
N90 Wheel: 15 multiplied by 7, Aluminum Cast, 4.75 Inch Bolt Circle
N96 Wheel: 16 multiplied by 8, Cast Aluminum
PA3 Wheel: 15 multiplied by 7, Aluminum, Styled
PF2 Wheel: 15 multiplied by 7, Aluminum
PH1 Wheel: 15 multiplied by 7, Steel
PNV Carrier: Inside, Spare Tire
P16 Carrier: RR Mounted, Spare Tire
QBF Tire, All: P235/70R15, BW
QBG Tire, All: P235/70R15, WOL
QCA Tire, All: P205175R15, WOL
OCB Tire, All: P235155R16, BW
QCE Tire, All: P205175R15, BL
QEB Tire, All: P235/75R15, WOL
QJJ Tire, All: 31 Multiplied by 10.5 R15LT/C, BW
QLN Tire, All: P235/70R15, BW TL HWY
RYJ Covering: Cargo Area, Retractable
TB4 Body Equipment: Liftgate
TR6 Headlamps Control Leveling System, Manual
TT6 Headlamps: High Intensity Discharge
T37 Foglamps: Deluxe
T61 Daytime Running Lamps
T62 Daytime Running Lamps - Delete
T84 Headlamps, RH Rule of Road, E-Mark, Rectangular
T89 Tail Lamp and Stop, Export
T90 Lamp Signaling and Marker, Export
T98 Stamping Vehicle Identification Number
UA1 Battery: High Capacity, Wet
UC2 Speedometer Inst, Kilo & Miles, Kilo Odometer, Positive Bias
UC4 Speedometer Inst, Kilo & Miles, Miles Odometer, Positive Bias
UD4 Alarm, Vehicle Speed, 120 K/H
UK3 Steering Wheel Radio Controls
UK6 Radio Control: Rear Seat and Ear Phone Jacks
UL0 Radio: AM/FM Stereo, Seek/Scan, Auto Rev Music Search Cass.
UL2 Frequencies, European Radio
UL5 Radio: Delete
UM6 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Clock, ETR
UM7 Radio: AM/FM Stereo, Seek/Scan, Clock, ETR
UN0 Radio: AM/FM. Seek, Scan, Compact Disc, Auto Tone, Clock
UP0 Radio: AM/FM Stereo, Seek/Scan, Auto Rev. Music Search Cass, CD, Auto Tone, Clock, ETR
UP8 Provisions: Stereo Radio
UQ3 Speaker System: Performance Enhanced Audio
UW3 Radio: AM/FM Stereo, Seek/Scan, Auto Rev Music Search Cassette
UY7 Wiring Harness: Heavy Duty, Trailer
U1F Radio: AM/Fm Stereo, Seek/Scan, Compact Disc, Clock, ETR, HPS, Auto Rev Music Search Cassette
U1Z Multiple Compact Disc Player, Passenger Compartment
U16 Tachometer, Engine
U19 Tachometer, Engine
U73 Speedometer Inst, Kilo & Miles, Kilo Odometer
U75 Antenna, Fixed, Radio
UB1 Wiring Harness: Light Duty, Trailer
VF6 Bumper: Rear Step
VF7 Bumper: Rear Step, Delete
VGC Protector Film, Paint Etch Preventative
VJ4 Label, Export Child Seat Location
VL4 License Plate Front Mounting Package, EEC
VR4 Trailer Hitch: Weight Distributing Platform
VR6 Hook. Tie Down Shipping
VXS Vehicle Complete
V10 Provisions: Cold Climate
V37 Bumper: Front and Rear, Chrome
V4A Performance Package: Chevrolet X-Treme
V54 Luggage Carrier: Root, Painted
WJ7 Trim Override Interior: Leather, Oldsmobile Only
WXS Provisions; Wiring, For Communications System
WX7 Provisions, Wiring, Export
X88 Conversion Name Plate: Chevrolet
YC3 Convenience Package: Level #3
YC5 Convenience Package: Level #5
YC6 Convenience Package: Level #6
YC7 Convenience Package: Level #7-GMC Only, Envoy
YE2 Convenience Package: Level 2, Low Trim, Export
YE3 Convenience Package: Level 3, High Trim, Export
YG4 Optional Seats Not Desired
ZAA Compact Spare Tire
ZA6 Canadian Sales Package, Price Leader
ZA7 Canadian Sales Package, Value Leader
ZM5 Sales Package: Underbody Shield
ZM6 Chassis Package: Off-Road Suspension
ZM8 Sales Package: Combination, Elect. Tailgate Release/Rear Window Defogger
ZQ1 Chassis Package: Smooth Ride
ZQ2 Sales Package: Driver Convenience I
ZQ3 Sales Package: Driver Convenience II
ZQ6 Sales Package: Driver Convenience III
ZQ8 Package: Sport Chassis
ZR2 Chassis Package: High Rider Performance, 4X4 Sport
ZW7 Chassis: Premium Smooth Ride
ZY1 Color Combination: Solid
ZY2 Color Combination: Two-Tone, GMC Only
ZY7 Color Combination: Lower Accent, Two Tone
Z49 Base Equipment: Canadian Mandatory
Z5X Mirror Provisions, Arabic Language
Z70 Conversion Nameplate: Oldsmobile
Z82 Trailering Provisions, Special Equipment, Heavy Duty
Z83 Chassis Package: Solid Smooth Ride
Z85 Chassis Package: Increased Capacity
Z88 Conversion Nameplate: GMC Truck
01L Secondary Color Exterior: Special
O1U Primary Color Exterior: Special
1SH Diamond Edition: Standard Equipment Package
1SJ Diamond Edition: Luxury Equipment Package
1SK Diamond Edition: Special Equipment Package
11A Stripe: Color Accent, Pewter
11L Secondary Color Exterior: Pewter Met.
11U Primary Color Exterior: Pewter Met.
12D Trim Combination: Cloth, Graphite (D)
12H Trim Combination: Cloth, Graphite(H)
12I Interior Trim: Graphite
122 Trim Combination: Leather, Graphite
23U Primary Color Exterior: Space Blue Met.
37U Primary Color Exterior: Green Tintcoat Met.
39L Secondary Color Exterior: Indigo Met.
39U Primary Color Exterior: Indigo Met.
41L Secondary Color Exterior: Black
41U Primary Color Exterior: Black
44U Primary Color Exterior: Medium Red Met.
50U Primary Color Exterior: Olympic White
54A Stripe: Accent, Brt Gold
55A Stripe: Accent, Lt. Autumwood Met.
60L Secondary Color Exterior: Gold Met.
60U Primary Color Exterior: Gold Met.
61A Stripe: Accent, Gold Met.
64D Trim Combination: Cloth, Light Beige
64H Trim Combination: Cloth, Light Beige
64I Interior Trim: Light Beige
642 Trim Combination: Leather, Smokey Carmel Tin
65U Primary Color Exterior: Smokey Carmel
68U Primary Color Exterior: Copper Met.
74U Primary Color: Exterior, Victory Red
8E1 Fuel Additional: Three Gallons
90A Stripe: Color Accent, Medium Gray
90L Secondary Color: Exterior, Gray Met.
91A Stripe: Color Accent, Spectre Gray Met.
92D Trim Combination: Cloth, Med. Dk. Pewter (D)
92H Trim Combination: Cloth, Med. Dk. Pewter (H)
92I Interior Trim: Med. Dk. Pewter
92W Trim Combination: Vinyl, Med. Dk. Pewter
922 Trim Combination: Leather, Med. Dk. Pewter
94U Primary Color: Exterior, Cherry Red Metallic
96A Stripe: Color Accent, Silver
Old 12-31-2020, 12:45 PM   #3
Grizz1963
Grizz1963's Avatar
Thank you very much Warren.
That’s great.
HIT AND RUN TRUCK COLLECTION.
In the end, I capitulated and decided to just pay the road tax and not mess the seller around, risking my deposit.
So off we went.
And on and on the road went.
Made it to the sellers place, played a pretty good game of remote hand over, electronic fund transfer etc, then two old guy from the same area of South London touched base, comparing notes.
Good byes said, Mickey headed home on his own, I headed for the local gas station with a thirsty truck with empty tank.
55 liters meant there was some distance left in it after the previous owner had put some gas in for the test drive.
On the way home I did a detour to drop off some air tools for @pauly to use on Woody his C10 that he is quietly getting on with.
Paul took a happy new owner pic for me.
Freezing cold out there.
Then headed home.
Stopped at my local gas station, and missed out taking a pic of the signs on the gas pumps that say: “DO NOT TOUCH OUR PUMPS”
But the ladies who fill the cars and trucks soon make you forget that, with their friendly approach and service.
Real old skool
So 85 miles and the consumption at presto much mostly motorway speeds around 70mph.
27mpg or 10km/l
Happy for sure.
Sunset outside at the gas station.
Then back home, 2’C outside meant I just reversed up the drive, locked up and went indoors.
Grinning.
Happy yes.
