09-18-2010, 10:01 AM | #1 |
Diffeence Between Integral Head & Non Intergal
So what is the difference between the two? Is one better then the other? What years where each made? I was thinking of looking for a streight 6 and want to be informed. Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
09-18-2010, 10:43 AM | #2 | |
Re: Diffeence Between Integral Head & Non Intergal
An integral head has the intake manifold built into the head itself. It is all the same casting. The earlier "non" integral head has the intake manifold as a seperate casting that bolts-on just like the exhaust manifold.
As a general rule, most guys prefer the non integral.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-18-2010, 10:43 AM | #3 |
IMO I would look for the older model inline six. The intergral head come out in the late 70's I think. I know my 81 has one. The intake manifold is cast with the head so there's no changing them for any performance parts. Now I don't know if the head off a older motor will fit the new blocks as I haven't researched it.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ Last edited by fishingjred73; 09-18-2010 at 10:45 AM. |
09-18-2010, 10:59 AM | #4 | |
The integral heads started in '75, IIRC.
You can use either one, they interchange.
09-18-2010, 01:40 PM | #5 |
The intregal head came out in 75 like Longhorn say's although they didn't use it on Camero's & 292's. They were real bad about cracking the heads & ex. manifolds & broken bolt's in the ex. manifold. The head was ungodly heavy & burdened down with weird emission control gadget's. It's best to stay away from them.
09-18-2010, 09:30 PM | #6 |
Don't let the above discourage you if you have the chance to buy an otherwise good engine with an integral head. As already mentioned, the earlier head is a straight across swap on any of the 63-up inline sixes.
Ray Last edited by raycow; 09-19-2010 at 01:05 AM. |
09-19-2010, 10:05 AM | #7 |
Thanks for the replys. Great Info.
