08-31-2012, 10:46 AM | #1 |
ebay stainless steel headers and burb elec speedo
ordering headers real soon for my 85 5.3 swap has anyone used the stainless steel camaro headers on ebay? they are around 70$ cheaper than the plain pacesetters on tight budget could use that 70 on other parts. and ayone tell me where i can find wiring diagram to make 90 burb cluster work? hope to have pics up soon thanks guys
Posted via Mobile Device |
08-31-2012, 12:30 PM | #2 |
Re: ebay stainless steel headers and burb elec speedo
I used the Sanderson CSLS1 headers ( shorties) on my swap
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-31-2012, 06:09 PM | #3 |
meowMEOWmeowMEOW
which year Camaro?
I think you square body guys have more room in between the rails than my 66 does, but even so fbody headers might be a bit of a squeeze. Trailblazer SS stock manifolds fit easier than almost anything else, but if you want longtubes the Dough Thorley is a preferred but PRICEY option. You may try gen5 Camaro headers, as there have been some recent posts on them fitting well (the stock ones that is). Fitment can be different even on two of the same year trucks, since the front->back positioning is different based on which mounts, which position etc the engine is in.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-31-2012, 07:51 PM | #4 |
the 98-02 f body headers are supposed be a great fit pacesetters on ebay with gaskets and hardware are about $270. i like the sanderson and others they look really nice but too expensive.
08-31-2012, 09:36 PM | #5 |
I tryed a set on my 85 4x4 burb. driver side fit great but collector was in side the frame. Then i tryed to shift out of park. Shifter linkage hit the headers. passenger side hit the schakels on my burb. Also had to trim the trans. Took them off and when avalible i was about the first to order doug thorlys. Fit great. But expensive.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
