Old 05-12-2021, 07:26 AM   #1
Haybag
LS swap fires then quits
Swapped a 99 4.8 into my 72 c10. Got everything hooked up and ready to run. Starts immediately and then quitsafter a few seconds.. Computer was sent to Lt1swap.com to remove vats and what was not needed. In searching my issue it sounds like vats, how do I test for that or what else could be the problem? Thanks in advance.
Haybag is offline   Reply With Quote
Old 05-12-2021, 07:39 AM   #2
mongocanfly
mongocanfly's Avatar
Re: LS swap fires then quits
Do you have the maf hooked up?
Any codes?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-12-2021, 07:42 AM   #3
A1971Blazer
A1971Blazer's Avatar
does the fuel pump prime for a few seconds when you turn the key to "on" if so make sure it's also running when you get it started.
If so the VATS may not be disabled?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 05-12-2021, 07:53 AM   #4
Haybag
Maf is hooked up. Checked with a scanner and shows no codes. Pump has power with key on and cranking, can hear it when I turn key on.
Old 05-12-2021, 10:16 AM   #5
Davidf
Maybe check fuel pressure. You have enough gas in tank, right!
Maybe crank sensor...but usually that is a no start situation, not a run and stop scenario.
Hope you get if figured out. Soon I will have my 2001 5.3L dropped in my '71...I am always nervous what is happening to you will happen to me. I too had LT1SWAP reprogram my ECM/PCM.
EDIT: Per other thread...check for massive vacuum leak...such as leaving a port on the manifold wide open.
Davidf is offline   Reply With Quote
Old 05-12-2021, 10:44 AM   #6
ls1nova71
ls1nova71's Avatar
Can you keep it running by feathering the throttle? I have had swaps that when you first hook up the battery after it has sat a while with it unhooked, that it won't stay running. It has to recalibrate where the IAC is, and once it's done that runs fine there after.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-14-2021, 09:26 AM   #7
Haybag
Found my problem, forgot to plug hole in intake for egr tube, huge vacuum leak! Starts and runs now, just need to put exhaust and 02 sensors on.
Old 05-14-2021, 09:37 AM   #8
A1971Blazer
Good news!
that also shows how difficult it is to diagnose a problem without actually being there in person...an extra set of eyes is most always helpful....
1967 C10 Step side
1968 C10 Step side
