Old 05-02-2012, 07:15 PM   #1
70elcamino
drum brake problems
I have adjusted the pads all the way open and my brake drum wobbles but wont come free. I tried pryin on it and beaten on it with a hammer but no such luck. Eventually changing to disc but need these to last a little longer til i find a money tree. Any ideas
70elcamino is offline   Reply With Quote
Old 05-02-2012, 07:20 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: drum brake problems
Try adjusting the brakes in instead of opening them up. I usually use a thin screwdriver to push on the adjuster while turning the gnurled knob.
68gmsee is offline   Reply With Quote
Old 05-02-2012, 09:47 PM   #3
70elcamino
i have adjusted them to where they spin freely but they dont come off.
Old 05-02-2012, 10:12 PM   #4
cableguy0
back the adjust off as far as it will go. If that doesnt work theres probably a large lip on the drum meaning its worn out. If you back the adjuster all the way off and they still wont come off use a cut off wheel or grinder to take the heads off of the shoe spring pins that come through the backing plate. that should allow the shoes to move enough to get the drum off.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-03-2012, 04:31 AM   #5
cdowns
cdowns's Avatar
you dont have spring clips on the wheel studs do you??
Old 05-03-2012, 09:20 AM   #6
68gmsee
Active Member
68gmsee's Avatar
...... use a cut off wheel or grinder to take the heads off of the shoe spring pins that come through the backing plate. that should allow the shoes to move enough to get the drum off.
Good idea. And the brake spring kit contains the replacement parts.
Old 05-03-2012, 03:26 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
power sledge hammer time
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-06-2012, 06:05 PM   #8
GRX
GRX's Avatar
^^ this ... also .... it is very common for the drum to become tight on the center hub from rust & dirt etc. A bit of PBlaster spray and some heat from a small hand torch (on the drum only) usually does the trick. Often times the drum will pop right off. Have run across this many many times.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 05-06-2012, 07:29 PM   #9
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
this is how i do it...clip or no clip, i just avoid hitting the weights and it will give...if it doesn't pop off with a moderate swing...get mean at it
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
