02-20-2021, 12:25 AM | #1 |
Need PorterBuild Mild/Touring LS Steering HELP
Hey guys. I’m mocking up some parts here and it seems my steering is going to be really tight. Just wondering what you guys with this setup Are using and how’s you do it.
From what I’ve researched it appears Im going to need a 30” column and 3 joints to get the proper angles. Also some guys mention an idler bearing as well. Im running a Pb drop member with LS and Holley manifolds Any thoughts.? Thank you in advance .. Posted via Mobile Device |
02-22-2021, 12:09 PM | #2 | |
Re: Need PorterBuild Mild/Touring LS Steering HELP
02-22-2021, 02:33 PM | #3 |
Here is a pic of the steering on my 53 Suburban that is running PB. it should be a very similar set up to your PB set up. The carrier bearing mount that PB provided as a thin (3/8") plate that bolts to the back side of the A-arm with a hole for the bearing to bolt to.
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-22-2021, 10:50 PM | #4 | |
Looks pretty similar to my setup. Do you have other Pic angles and where did you that tab from ?
02-23-2021, 09:27 AM | #5 | |
Thanks Marc
02-24-2021, 02:42 PM | #6 |
Youngrodder that is very clean!
I dont have a Porterbuilt (though should have gotten one) but had to reroute my steering for my Z. I welded a bracket to the frame for my support.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-24-2021, 10:29 PM | #7 | |
Sweet man. Thanks for the pics , That’s the cleanest one I’ve seen yet. You said you got it from PB ?
02-25-2021, 09:07 AM | #8 | |
Thanks Marc
02-25-2021, 08:58 PM | #9 |
Spoke with Nate today. He said the pics I sent of your setup are from an extreme DM. I have a touring stage II dm on mine. We agreed that once I have the column and headers in place to send him pictures to determine where the idler bearing is going to be. Posted via Mobile Device
02-26-2021, 10:55 AM | #10 | |
Thank you Marc
02-26-2021, 08:23 PM | #11 |
[not at all bud. Thanks for your help. Hopefully we can get this resolved soon. Thank you !!! QUOTE=youngrodder;8885609]Got it. OK I didn't realize that yours was a pro-touring set up. I apologize if I missed that detail.
Thank you Marc[/QUOTE] Posted via Mobile Device |
