Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 10-09-2014, 12:27 AM   #1
bigblock73
yeller
bigblock73's Avatar
47-54 cab corner speaker brackets
NEW PRODUCT! For those who have, or are about to, relocate the in-cab gas tank on your 47-54 (55) GM truck, I now offer these cab corner speaker brackets. Made of heavy 16 ga steel and laser cut, these are high quality brackets engineered to fit nice and snug into the corners of the cab. These come in two versions, one with pre-cut 6x9 openings, the other blank...allowing you to use the speaker(s) of your choice. Brackets come with detailed instructions and mounting hardware. Price per pair is $85 shipped to anywhere in the lower 48 states, my PayPal is jdrew@73-87.com
If you have any questions or concerns, please visit the links in my signature and review the feedback on the 73-87 and 67-72 brackets I also sell. I take great pride in the products and services I offer, and put a lot of work in these to ensure you are satisfied.
As of 10/8 I have very limited quantities...7 pair with the 6x9 opening, 3 pair blank.
bigblock73 is offline   Reply With Quote
Old 10-09-2014, 12:36 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 47-54 cab corner speaker brackets
Here is a picture of a blank one mocked up in forum member Torchlight's truck. As you can see, these fit tight to the B-pillar and rear cab wall. Because he has not picked his speakers out yet, he opted for a blank pair...and until the hole is cut for the speaker opening, the shop mounted the floor bracket to the front side due to lack of access to the rear (where these are designed to mount)
Old 10-09-2014, 12:46 AM   #3
bigblock73
yeller
bigblock73's Avatar
Some very minimal trimming to the lower portion of the cab, just behind the B-pillar/above the seat riser is required to get these snug up against it the B-pillar. Additionally, the brackets are cut to follow the curve of the rear cab wall...there may be some very minor shaving of the brackets required due to variances from truck to truck and how this panel fared over the years.
Old 10-09-2014, 12:53 AM   #4
bigblock73
yeller
bigblock73's Avatar
Last picture, showing both sides installed in my friends '52. Brackets will clear the stock bench, and should work with all seats similar in size. The inner bends of the brackets are also further out from the rear cab wall and the vertical supports, so one could easily run a filler panel from bracket to bracket, finishing off the rear cab wall nicely.
Old 03-25-2015, 04:53 PM   #5
HUSSEY
HUSSEY's Avatar
I just recived a set of these speaker brackets for my 49 AD. I was really impressed by the level of craftmanship and detail in them, they are simply not just a bent up piece of sheet metal. They have detailed cutouts and curves that hug the body of the truck. I've only test fitted them for now but they look like they will install really well.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 04-09-2015, 09:39 AM   #6
bigblock73
yeller
bigblock73's Avatar
Thanks for the feedback...this is what keeps me offering these parts. Please post installed pics when you get to that point, and send any feedback you might have, so I can make adjustments if needed.
Old 05-23-2015, 07:53 PM   #7
bigblock73
yeller
bigblock73's Avatar
Weekend bump
Old 06-01-2015, 02:39 AM   #8
tpimuncie
tpimuncie's Avatar
Are you planning on making any for 55-59s or would these work ��
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 08-25-2015, 08:20 AM   #9
bigblock73
yeller
bigblock73's Avatar
Ttt, just got a new batch of brackets in stock.
Old 09-09-2015, 01:01 AM   #10
tpimuncie
tpimuncie's Avatar
Any 55-59 yet?
Old 09-29-2015, 12:05 AM   #11
bigblock73
yeller
bigblock73's Avatar
Originally Posted by tpimuncie View Post
Any 55-59 yet?
You are in luck...finally picked up a 58/59 GMC parts cab this weekend. In the process of stripping it down and cleaning it now so I can start the design (and sell some of the parts hopefully). As I get closer, I will post an update in a new thread. Thanks for your interest.
Old 09-30-2015, 05:30 PM   #12
tpimuncie
tpimuncie's Avatar
Sweet!
Old 09-30-2015, 08:35 PM   #13
Donaldo
I have a set that I welded into the corners of my '51. Light gray pearl inside cab color.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 10-03-2015, 10:58 PM   #14
mobileortho
mobileortho's Avatar
Any more of the 47-54's left?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-04-2015, 04:18 PM   #15
bigblock73
yeller
bigblock73's Avatar
Yessir, both styles. If interested, price is still $85 to your door, my paypal is jdrew@73-87.com
Please specify with or without speaker opening cut when ordering.
Old 10-04-2015, 04:19 PM   #16
bigblock73
yeller
bigblock73's Avatar
Looks great Don!
Old 10-04-2015, 06:52 PM   #17
mobileortho
Great! Payment sent!
Robert C.
1950 3600
Old 11-02-2016, 08:32 AM   #18
bigblock73
yeller
bigblock73's Avatar
Hump day bump
Old 11-13-2016, 07:52 PM   #19
CheyenneSuper72
I will take a set of the 47-54 brackets. PayPal sent. Thanks.
CheyenneSuper72 is offline   Reply With Quote
Old 03-06-2017, 09:55 PM   #20
bigblock73
yeller
bigblock73's Avatar
Ttt
Old 03-11-2017, 10:21 AM   #21
cff
Active Member
I hope you start making them to fit the 60-66 pickups. I would be buying a couple pairs and I'm sure there would be many others. Ron
cff is offline   Reply With Quote
Old 06-30-2017, 04:33 PM   #22
coker1939
Drew,
I was just wondering if you are still making rear speaker brackets for 1947-1954, I have a 53 and looking for a set with cutouts, I saw your post last year in April 9th 2016, but I wasn't ready to install my stereo system until now. Hopefully you still are.
Thanks Danny
coker1939 is offline   Reply With Quote
Old 06-30-2017, 04:34 PM   #23
coker1939
Are you still selling stereo brackets for 47-54, and if so what is the current price with shipping if needed? Thanks Daniel Coker
Old 09-14-2017, 01:46 PM   #24
bigblock73
yeller
bigblock73's Avatar
Daniel, sorry for missing your post. Yes I am. You can see/order them on my site www.73-87.com
Old 12-05-2017, 10:51 AM   #25
SFFD103
SFFD103's Avatar
I r chives mine and they look great. Won’t be a while till I install them since I’m doing A frame off restoration but couldn’t pass them up. Yes thanks
SFFD103 is offline   Reply With Quote
