04-28-2014, 02:09 AM | #1 |
This 42 n-experienced mech needs help
1st off, I have an '85 c20 that I am trying to bring back to life after my 17 yr. old got a hold of it. Funny thing is I'm trying to do the mechanicing to put a 3rd vehicle on the road, so he can go to college(across town in the new vehicle!! Ha LOL
Anywho, The problem i have is i went to change the Valve Covers and gaskets and saw this on the driver side head. I DO NOT know much of any thing internal engine. Please any advice that could be given on how to fix this, CHEAPLEY AND QUICKLY!! I appreciate it. |
04-28-2014, 07:09 AM | #2 |
Re: This 42 n-experienced mech needs help
Well one where is the rocker and nut second you need to figure why the push rod bent bad cam stuck valve and so on smack the valve a few times with a hammer see if it moves if it moves and returns freely you can try a new push rod and rocker about 10 dollars but you could still have a bad cam or rocker stud pulling loose from head
04-28-2014, 09:15 AM | #3 |
could be a bent valve, not cheap or quick. Do what truckdude said and smack the valve spring with a hammer lightly, the spring height should be the same as the rest after, if not, then it is a bent valve (AND bent push rod). If you don't understand any of this I would recommend getting a friend who might, to take a look.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
04-28-2014, 09:36 AM | #4 |
Active Member
Tapping on the valve may help you determine if it's stuck but if it's something bent further up the valve stem then the best tool to check valve to see if it's binding is one like I use. Put the nut on the threaded stud and press it down. If you don't have one use something for leverage like a pry bar or long screwdriver. Maybe with a washer under the nut.
If valve moves freely with no binds, replace the rod or maybe even straighten it out to check the engine out. A backfire because of timing problem can also cause this to happen so be sure and check the timing and adjust the lifter correctly.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
04-28-2014, 11:28 AM | #5 |
Still curious about where the rocker and nut was and what kind of shape they were in.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
