Old 02-06-2024, 12:32 PM   #1
Brownsquare
'87 floor shift steering column.
My '87 GMC is a three speed manual with a column shift. I'm converting it to a floor shift and would like to get rid of the manual shift 'nub' on the column. I've read that it's not as simple as swapping collars to a floor shift unit, so I've planned on hitting FB Marketplace to see if I can find a column from a factory floor shift truck. I can't imagine it'll be that difficult since I'm not after tilt or cruise, just a plain floor shift column.
Here's my question: My truck currently will start without the key, or you have to start it with the key but then you can remove it (can't remember which). If I swap to a floor shift column, does this year square have a lockout to keep you from starting the truck in gear? If I go to a floor shift will I have to rig something up?
Thank you!
Brownsquare is offline   Reply With Quote
Old 02-08-2024, 07:30 PM   #2
shambles
Junior Member
Re: '87 floor shift steering column.
Hello,
Not sure if they are the same, but On my 1978 GMC 3 speed column shift the Neutral Safety Switch is activated with the clutch pedal. There is a little tab on the pedal arm that presses the switch.
shambles is offline   Reply With Quote
Old 02-08-2024, 09:49 PM   #3
raggedjim
raggedjim's Avatar
I'm not real familiar with the 87 but I cut the nub off of my 68 with a hacksaw and filled the collar with JB weld. You can check out my build thread starting at post 107 and see how I did it. You would have to disassemble the column to do this.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 02-08-2024, 11:02 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Thank you!
Floor shifts had a tab you pushed to release the key.
Had to push it remove key and then it would lock.
Old 02-08-2024, 11:07 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Thank you!
And the clutch pedal was the neutral safety.
Old 02-09-2024, 11:05 AM   #6
Keith Seymore
Keith Seymore's Avatar
On my '80 (back in 1980) I also cut the nub, but mounted the Sun tach over the hole.
I left the column assembled and in place, and just packed the opening with paper towel to keep any shavings out.
I pinned the column bowl in the up position to not effect key removal.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
