12-28-2009, 11:22 AM | #1 |
Steering box differences...hydro or not
I'm making a junkyard run today to look for a good 2wd steering box cause I'm planning for crossover steering. However I'm also going with hydroboost brakes. Is there any difference in the steering box between a hydroboost & vaccuum brake trucks?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
12-28-2009, 12:08 PM | #2 |
Re: Steering box differences...hydro or not
To my knowledge there isn't a difference. I put hydroboost on my 69 K20 and am still using an older style power steering gear box. I did have to have the high pressure end swapped on one of the hydroboost lines to work with my existing box. Swapping to a newer 4wd steering box would have made that unnecessary.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-28-2009, 05:57 PM | #3 |
same box different pump
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-29-2009, 12:24 AM | #4 |
Thanks y'all...
I did find a good donor steering box on a '86 burb...$35. Also discovered a near perfect set of '69 metal door panels...$15. I love going to the junkyard!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 Last edited by fun in dirt; 12-29-2009 at 12:25 AM. |
