Old 05-02-2021, 07:09 PM   #1
warndogg
warndogg's Avatar
Where to buy lowering components
Well it's time to lower my 1970 short bed! I would like an honest opinion from those in the know. I've been doing a lot of research and thinking the Grand slam kit from CPP looks good (cost) plus all in one kit. Currently have power drum brakes and would like a 4/6 drop. I have read a lot of negative reviews about CPP's support. I'm thinking of ordering it through Summit if I have any problems I can go through Summit instead of CPP. Belltech and others do look to be top quality I just can't see spending several thousand dollars more. Anyone have good luck with CPP?
warndogg is offline   Reply With Quote
Old 05-02-2021, 09:20 PM   #2
Clyde65
Clyde65's Avatar
Re: Where to buy lowering components
99% of my suspension is CPP.
Their quality is good imo, customer service blows beyond understanding as you know.
Summit is a great place to buy, they are power buyers so they get good deals.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-02-2021, 09:42 PM   #3
warndogg
warndogg's Avatar
Thanks Clyde that makes me feel a lot better by buying.
Old 05-03-2021, 01:54 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
I just got some choppin block A arms and are built stout.
And being sort of local helped in my choice
Old 05-04-2021, 08:12 AM   #5
67C10Step
67C10Step's Avatar
I purchased all my CPP front drop pieces from Summit. Spindles, rotors, and calipers. It all went together with no issues so I didn't have to get any customer support from CPP. The only complaint I had was if you buy the powder coated calipers and don't want to chip the powder coat you will need to test fit and clearance the spindles just a bit. I chipped the heck out of both my calipers getting them installed but since it's not gonna be a show truck I didn't sweat it too much. Touch up the chips with some black paint.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 05-04-2021, 08:21 AM   #6
warndogg
warndogg's Avatar
That sucks for sure, did you have to change the spindles?
Old 05-04-2021, 09:34 AM   #7
67C10Step
67C10Step's Avatar
I kept the 2-1/2" lowering spindles and just got the calipers to fit. I am thinking the powder coat was thicker than expected so the clearance to the "ears" on the spindles was too tight. In the end I was happy with all of it. WAY better than manual, drum brakes I had.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 05-04-2021, 10:53 AM   #8
warndogg
warndogg's Avatar
Gotcha, thanks for the heads up. It looks good! Any problems with wheel fitment?
Old 05-04-2021, 11:12 AM   #9
67C10Step
67C10Step's Avatar
I am running your standard 15x8 rally wheels and they fit fine with zero issues. I had read some stories about having to clearance a bit but I didn't find that to be required.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 05-04-2021, 11:23 AM   #10
warndogg
warndogg's Avatar
