09-12-2018, 02:16 PM | #1 |
Door hinges
I need some door hinges for the 54. I've been looking at Classic, LMC, Eckler's and Tucker.
Does anyone know if there is a difference in the products? I know the price ranges from $300 to $395, depending on which vendor. I've been trying to fund used, but of the 6 I have, I could rebuild 2, maybe 3 at best, and they wouldn't be great where the skinny metal is on the inside of the truck |
09-12-2018, 02:24 PM | #2 |
Re: Door hinges
Are they all the same from 47-54? I have about 6 of them with them all being rebuildable. But honestly, I would be looking for original ones, forget reproduction. Unless someone comes on and tells you of a brand that they got and worked, stay away from reproduction.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-12-2018, 02:25 PM | #3 |
Re: Door hinges
Here's a "Basics of Basics" I did on the subject.
https://www.hotrodders.com/forum/bas...es-125350.html Brian
09-12-2018, 02:37 PM | #4 |
Re: Door hinges
I've read "stay away from reproduction" on here.
The problem is I don't have 4 rebuildable hinges. I had to cut one to get it out of the cab. Two have the skin metal broken. So I'm looking for someone who will sell me 4 that I can rebuild if I can find them. |
09-12-2018, 03:40 PM | #5 |
Re: Door hinges
I have it on good authority that if I knew what to call the "inside skin" on the cab side of the door hinge that I could buy just that piece if I can't find rebuidable hinges.
So if anyone knows of a supplier for the "skin" on the hinge, I would like to know. |
09-12-2018, 04:14 PM | #6 |
Re: Door hinges
09-12-2018, 04:24 PM | #7 |
Re: Door hinges
Thank you Brian. I can fix 3 of the four hinges.
Now to find that elusive lower driver's side door hinge. I had to cut it up to get it out and now I need a replacement. |
09-12-2018, 08:36 PM | #10 |
Re: Door hinges
That is a hell of a build there Jan, holy crap that's nice stuff.
Brian
09-13-2018, 12:44 AM | #11 |
Re: Door hinges
thats hardcore, very cool, much respect. I will stop talking in staccato syllables soon.
09-13-2018, 09:56 AM | #12 |
Re: Door hinges
NorCal, now I have to go through your whole build thread. That is really great work. Thanks.
09-13-2018, 10:08 AM | #13 |
Re: Door hinges
After rebuilding my own hinges. I highly recommend sending your hinges to this guy
http://drjsrestorationrx.com/ He makes the hinge face plates the Filling Station sells. He may also have the hinge you're looking for. If you choose to do them yourself, he also has a "how to" video on Youtube. https://www.youtube.com/watch?v=aEoBFw8kaTE
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
09-14-2018, 05:52 PM | #14 |
Re: Door hinges
Got the hinge apart and took the face plate off.
IMG_2051 by Robert Moorman, on Flickr Then I welded the flange back to the hinge base. I had to cut it off to get to the hinge pin to cut it out. I bet I spent 30 minutes fitting it together before I finally welded it up. IMG_2052 by Robert Moorman, on Flickr Now it is slicked up. IMG_2053 by Robert Moorman, on Flickr I even test fit it in the door jamb to make sure the holes lined up. |
09-14-2018, 11:27 PM | #15 |
Re: Door hinges
Right on, there you go!
Brian
09-14-2018, 11:49 PM | #16 |
Re: Door hinges
nice repurpose man
09-15-2018, 09:48 AM | #18 |
Re: Door hinges
Ha, now to see if I can get the pins out of the other 3 hinges.
A big thank you to Jan! I'm going to have new face plates on the hinges, once I get them apart and rebuilt. |
09-15-2018, 06:17 PM | #19 |
Re: Door hinges
Is it possible to just bolt the new face over the old hinges?
09-15-2018, 06:36 PM | #20 |
Re: Door hinges
The face plates are spot welded on in 3 places. So the new ones will be spot welded as well.
09-15-2018, 07:11 PM | #21 |
Re: Door hinges
Under stood but Could the plates just be bolted on via the hinge bolts?
09-15-2018, 07:39 PM | #22 |
Re: Door hinges
I guess, but then you would have another adjustment to do when you adjust the hinge. Might make that a little more difficult.
09-15-2018, 08:00 PM | #23 |
Re: Door hinges
Thanks. My so called "restorer" destroyed my plates trying get door aligned and I don't have a spot welder. Hardly a day goes by and i find another major FU they did.
09-22-2018, 09:43 AM | #24 |
Re: Door hinges
IMG_2063 by Robert Moorman, on Flickr
Look what NorCalGal sent me! They are so nice that I think I'll frame them. But since I need them to use my door hinges, I guess I'll have to put them on the truck. I sure hope the truck turns out as nice as the hinge plates. Thanks Jan! |
09-22-2018, 12:32 PM | #25 |
Re: Door hinges
Those are friggin nice, wow.
Brian
