05-26-2021, 09:33 PM | #1 |
Hypothetical question
So I took my truck to a local engine tuner to get it fine tuned after my LS swap. He had it for 2 days and texted today that it was ready. I showed up and paid him and when I went to leave, I noticed my factory tach wasn’t working so I went back in to tell him.
His first response was he only hooked to the OBD11 port and didn’t mess with the tach or anything to do with it. I knew he had no reason to mess with the tach so at first I chalked it up to bad luck for me. Then on the drive home I remembered something he had said to me earlier. He said “I changed your shift point from 5000 to 5800.” I know he took it for a drive and he told me it was burning the tires between shifts. My question is this: if he revved the motor to 5800-6000 rpm while driving, could this damage the tach that only goes to 5000 rpm or would the needle just continue on past 5K? |
05-27-2021, 10:55 AM | #2 |
Re: Hypothetical question
My truck doesn't have a factory tach, but is there a needle stop at the top end of the gauge sweep? I'm wondering if pegging the needle against the stop wouldn't cause problems...
05-27-2021, 11:00 AM | #3 |
Is it an original factory tach or aftermarket? I've had a couple of aftermarket tachs burn up on me. The first one was warrantied, but the second one I had had too long. Took it apart and found a big resistor burned up on it so I tried replacing it to see if it would fix it, it did not. Bought another one and so far so good, but I think the quality of a lot of aftermarket parts is just abysmal at best. The stuff only sells because there isn't a lot of other options.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-27-2021, 12:47 PM | #4 | |
This is an original tach, not aftermarket. Do you think revving it past 5k would cause it to stop working? The computer is outputting as it should. |
05-27-2021, 05:26 PM | #5 |
You would think they got wound higher than 5k rpm on test drives when they were new. GM must have known they would get revved past 5k rpm. I would chalk it up to bad luck and old age.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-27-2021, 09:34 PM | #6 |
I seriously doubt over revving it would hurt the tach. Like te other guy said, it's probably just bad luck and/or age.
