Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 07-05-2002, 09:47 AM   #1
XXL
Señor Member
XXL's Avatar
Product review --- POR15's POR-Strip Stripper and Solvent
Feel like wasting $26+ dollars? Well, if so, try POR15's POR-Strip
Here's what they say--
POR-STRIP ® Paint Remover/Stripper is a clear spray-on remover with the consistency of water. In sample testing, our POR-STRIP ® was the choice of professional auto strippers. A special chemical-resistant spray bottle allows you to use less and finish faster than brushing. Remove any coating from any surface without damaging window glass, chrome, or weatherstrip. POR-STRIP ® is nonacidic and will not harm aluminum or factory fiberglass.
On a recent order, I bought a gallon of this stuff along with some POR15. My plan was to strip the black enamel off of a bumper I'm working on. After following the directions on the package, I didn't get any paint stripping results... so I tried it again, and AGAIN! Paint not removed, not loosened, not anything. So, just in case this bumper had been painted with some kind of super paint, I decided to try the stripper on part of a cab I'm working on. Same thing... 3 separate attempts at following the instructions (instructions call for 2 separate coats, so we're up to 6 coats in all) and guess what? The paint is still there. It did manage to bubble up a small swath of uncoated body filler and burn my skin a bit when the "free chemical-resistant spray bottle" managed to spring a leak in the trigger after about a dozen pumps.
BTW, they were right about not harming anything... including the paint I was trying to remove. As for being nonacidic, I am going out to the garage to re-read the label in a little bit. I seem to recall that the product contained muriatic acid.
Kenneth
XXL is offline   Reply With Quote
Old 07-05-2002, 09:55 AM   #2
Shane
Shane's Avatar
Thanks for the heads-up! I was actually planning on buying some to strip the inner fender wells. Looks like I will save a little more cash and buy a small pressurized sand blaster!
Shane is offline   Reply With Quote
Old 07-05-2002, 10:00 AM   #3
johnnyp
Keepin' It Stock
johnnyp's Avatar
I'd call POR-15's tech support. I've had good luck with them in the past. Or email your post to their tech support. They do a lot of business with members of this board and I think they'll want to make it right. Let us know what kinda response you get.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-05-2002, 10:08 AM   #4
Bondoman
I am just begining in restoring my truck and have very limited knowledge of body work but i have tried a few strippers on my truck now.
I paid 20 bucks for a stripper at advanced called tal-strip .... worked ok lifted top coat off with just brushing it on once. Did nothing to the heavy layers of primer untill more coats were added then still alot of wire wheeling to remove to metal .... plus made a mess everywhere.
Just because it was cheap i bought another stripper at home depot paid $3.99 for a quart and came with sprayer. It is made by Binks if i remember correctly and worked just as good as the expensive. Also worked better on the primer coats and evaporated much faster than other so no mess.
So just in case any others like me are looking for a stripper this worked well for me.
Bondoman is offline   Reply With Quote
Old 07-05-2002, 11:20 AM   #5
BubbaGreen
Want something that removes paint:
Go to walmart and get stuff called 'DADs' paint remover,
it comes with a small spray bottle, but it can be brushed on.
This stuff works, I mean it really works. Usually the first coat
will remove any paint with in minutes. It use to be available
by the gallon, but the last time I went to get some, they only
had the quart size. Just dont get it on anything you dont
want it on, and keep it off your skin....burns like *#$$%#
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 07-05-2002, 09:14 PM   #6
XXL
Señor Member
XXL's Avatar
Done. Thanks for the suggestion. I'll keep you posted.
Kenneth
Old 07-05-2002, 09:19 PM   #7
mikep
Used to have a truck
mikep's Avatar
Or... you could always call the NAPA store in Poulsbo Washington and ask for the owner . He also manages the store and is there most days of the week. He also OWNS the POR company. He bought it last year. Thats why you find POR products in NAPA's now. Busy guy!
No truck :-(
mikep is offline   Reply With Quote
Old 07-10-2002, 11:42 AM   #8
XXL
Señor Member
XXL's Avatar
Update--
Mike Albrecht of POR stated via email that he'd refund me for the POR-Strip. I asked if he wanted me to return the product so they could evaluate it... he wasn't interested since 'he gets the product in 55 gallon drums so he would have known by now if there was a problem.'
To that I say...
1) I'm glad he saw fit to do a refund (though I haven't seen it yet... I hope I'm not appreciating it too soon).
2) So-so customer service isn't dead yet. He had the opportunity to be concerned, not just to "pay me off" (and sublimely state that his product is just fine-- thereby intimating it must be me that's the problem). How about... take the product back and analyze what might have been the problem-- bad batch? got 'neutralized' somehow in transit? customer (me) can't follow directions? customer is an idiot? Something. How about a chance to build customer rapport? Like, no refund but free replacement from another batch, and a "$5 goodwill coupon" for my trouble? This gets me chemicals that do what they were advertised to do AND ( A N D !!) gets me coming back for another product down the road. I don't have my hand out for a freebie... I would have been completely and thoroughly satisfied if their POR-Strip product had... uh... stripped.
Anyway, my rant here is winding down. I think I had reasonable expectations, and they weren't initially met, and they were only marginally addressed on their follow-up.
Oh well.
Kenneth
Old 07-10-2002, 02:36 PM   #9
johnnyp
Keepin' It Stock
johnnyp's Avatar
Thanks for the update XXL. I'd have to agree that the response wasn't what I would want either. If they didn't offer to send you a replacement and was quick to refund, kinda makes you wander if they know the product doesn't live up to its claims. I haven't dealt with the company since it was sold, so maybe somethings changed.
P.S. Let us know if you get your refund and if it includes shipping charge.
Old 07-10-2002, 04:21 PM   #10
Smooth68
Smooth68's Avatar
Just to lighten things up some Kenneth, you should have know it wasn't going to work very well - I mean after all it is called..."poor-strip"
I would think a company like that would be a little more concerned about a product with their name on it going out the door and not doing the job it's suppose to do. As far as he knows you could own a huge referb business and spread their name through the trenches....now that I think if it, you can do that anyways.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 07-10-2002, 05:30 PM   #11
XXL
Señor Member
XXL's Avatar
Yeah, but first I'll have to buy a huge refurb business
Kenneth
Old 07-10-2002, 06:08 PM   #12
Travis
Travis's Avatar
Unhappy
I understand what you are saying about customer support XXL, it seems nowadays that is the norm. Atleast in the the area I live in it seems to be that way, once a company reaches a certain sucess they just dont seem to care.
Travis is offline   Reply With Quote
Old 07-11-2002, 01:18 AM   #13
Hooter
My other Love
Hooter's Avatar
easy-off oven cleaner works real well to take off paint ive used it to strip some of the crappy maaco paint on the monte (uh-oh better get maaco) the 300 dollar embassdor paint job is a pile of crap if you ask me
MEMBER DISCS UP FRONT CLUB
  • 69 custom camper/cst 10
  • 70 monte carlo 383 stroker with a 700r4
  • 77 fully loaded silverado (back in the backyard for a little while longer)
  • 1980 BMW 320i (back in the garage finally)
  • 1981 f@*d f150 4x4 (Robert red ford) tried to kill me
  • 1972 Honda ct 90 trailbike
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com AC/DC RULES!!!
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-14-2002, 02:26 AM   #14
purple69
purple69's Avatar
por works real well guess the stripper doesnt
purple69 is offline   Reply With Quote
Old 07-14-2002, 10:08 AM   #15
XXL
Señor Member
XXL's Avatar
Refund check received in the mail yesterday for $27.00. I guess the extra buck is for shipping (??). Anyway, I appreciate Mike at POR taking care of this.
Kenneth
