07-11-2009, 03:02 PM | #1 |
Shortbed club member
Quick A arm question
My upper A arm is worn and clunks when I hit bumps.
Do I need to replace with a complete upper A arm, or can I just replace the A arm shaft. Basically, what usually wears in this situation. |
07-11-2009, 03:27 PM | #2 |
Re: Quick A arm question
Are the arms original to the truck or is there a possibility they were replaced w/some 73-87 arms?
The bushings for a 71 upper arm are rubber lined steel. The don't usually wear to the point of 'clunking' but it's possible. Are the alignment shims tight on the upper a-arm shaft where it attaches to the crossmember/frame? If some shims fell out, it would definitely cause some shifting of parts & give an audible 'clunk' when doing so.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-11-2009 at 03:28 PM. |
07-11-2009, 03:39 PM | #3 |
I can push & pull on the A arm and see it move while the shaft stays solid.
07-11-2009, 03:40 PM | #4 |
Watch out for your cornhole !
Bad bushings then. They are available through all typical parts stores.
07-11-2009, 03:44 PM | #5 |
Thats sortof what I thought. But when I looked at the lmc catalog
they only show a seal and a end nut, no bushing. |
07-11-2009, 04:35 PM | #6 |
That big nut on the end is the bushing itself. You have the screw in bushing and the little rubber seal. That's it.
LMC is going to overcharge you for this kind of stuff though. Local parts stores are cheaper for good quality stuff. LMC just resells stuff that they buy.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 07-11-2009 at 04:36 PM. |
07-11-2009, 05:02 PM | #7 |
Thanks for clearing that up for me TX.
Thats what I was unsure of. was going to buy locally, just using lmc as a guide. Last edited by Jack_71C10; 07-11-2009 at 05:05 PM. |
07-11-2009, 07:29 PM | #8 |
big guy
I have an upper set of A arms if you need them. Free just pay shipping and there yours.
Ray Last edited by lowdownstar; 07-11-2009 at 07:30 PM. |
07-12-2009, 10:48 AM | #9 |
You are better swapping them with the later arms that have rubber bushings. The length is the same and so is the bolt pattern for the balljoints. You can also but the replacement shaft and bushings at many chain auto parts stores
07-12-2009, 03:34 PM | #10 |
Why are the later with rubber bushings "better" ?
07-12-2009, 03:57 PM | #11 |
'Better' would be a subjective term.
The later bushings are more readily available & offer more 'cushion' for the high quality roads that 'daily drivers' seem to face everywhere. The earlier bushings would be 'better' from a performance/non-deflecting stand-point.
07-12-2009, 04:35 PM | #12 |
yes for an every day driver the rubber is better. if you want to feel every little pebble in the road the original bushings are better.
07-12-2009, 06:39 PM | #13 |
I'm thinking the tires have a lot more to do with feeling every little pebble in the road than the a-arm bushings ...
I only asked because I have used both and to be completely honest I cannot tell the difference sitting behind the steering wheel. I thought there was some fact-based reason for using the rubber over the solid bushing type, but apparently it's personal preference. Last edited by Shane; 07-12-2009 at 06:40 PM. |
07-12-2009, 08:02 PM | #14 |
vibration, a small amount but still vibration, just like the engine mounts and rubber in the steering column. Tires may have more to do with it but every place metal touches metal theres vibration transferred.
The ultimate would be tube arms with poly bushings but it all depends on funds and prefrence. |
07-12-2009, 10:08 PM | #15 |
Seņor Member
And one of those donut pillows to sit on.
07-13-2009, 09:35 AM | #16 | |
i have never rebuilt a control arm but am about to. |
07-13-2009, 09:40 AM | #17 |
The 'bushing' is a metal sleeve w/rubber lining the outer portion on the 6X-72's. The 73 & later arms have an actual rubber bushing in a steel shell.
07-13-2009, 10:22 AM | #18 |
To add to Scoti's response.
The control arm has a huge threaded hole in it. The bushing is the steel cap, which has threads on the outside of it. You screw the steel bushing into the threaded hole in the arms. Frankly, it's a real *****. In the past few years, I have started to run 73-87 arms simply because it's dead easy to press new bushings in place. Plus, I can get a full set of Energy Suspension control arm bushings for 73-87 arms for 60 bucks. The older arms with the steel bushings cost way more than that to get buy good bushings.
07-13-2009, 12:11 PM | #19 |
Never Ending Projects
BTW, the upper bushing nut is a 1 3/16" and the lower nut is a 1 5/16".
I ended up taking my arms to a buddy's shop and used their 3/4" drive impact to get them off. I got to do it for free instead of buying $100 worth of sockets and an adapter to my 1/2" drive impact.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-13-2009, 01:12 PM | #20 |
so maybe i should find some 73-87 A arms. do they bolt right up? just different bushings.
07-13-2009, 04:48 PM | #21 |
That's correct. They're a direct swap but use different bushing material.
07-14-2009, 08:34 PM | #22 |
I'm in the middle of this very thing right now. I was going to re-use all my old stuff, but I didn't like the way they were going on so I ordered new shafts and bushings.
A couple more questions-As the bushings thread into the arms, should the shoulder of the bushing/nut thread in all the way until it makes contact with the arm? Seems like I can get either the front or rear to touch, but not both. And how-which way-do the seals go? They are different, top and bottom of course, but which is the inside face? Any pictures of properly installed seals?
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
