Old 01-28-2007, 07:56 PM   #1
wannabeburbowner
wannabeburbowner's Avatar
Exclamation 22" wheels... Will they fit??
I am looking at some 22x10 wheels with 6.5" backspacing to put on the 71 c10. I am putting the truck on bags and will be laying frame. I won't be running inner fenders or stock rear wheel tubs. do you guys think the wheels will rub on anything, and will they tuck in behind the fenders and bedsides?? I just haven't had time to go measure stuff up, and figured would ask on here to see if anybody is running this set-up. And of course pics would be great to show some 22's and if you post please tell your tire size too.
Thanks for the help!
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 01-29-2007, 11:13 AM   #2
b&a72
Active Member
b&a72's Avatar
Re: 22" wheels... Will they fit??
I am running 9.5 with 5.5" backspacing 20's on mine and I have no rubbing issues as far as side to side but mine is only bagged. You should be fine as far as height.
b&a72 is offline   Reply With Quote
Old 01-29-2007, 11:31 AM   #3
jlaird
jlaird's Avatar
I don't think I have ever heard of anybody running 10" wide tires on the front. You better do your homework.
jlaird is offline   Reply With Quote
Old 01-29-2007, 12:27 PM   #4
b&a72
Active Member
b&a72's Avatar
I belive there is a member here that is running 10" rims on the front I don't remember his name but when I find him I will let you know. The only problem you will have is the backspacing you will probably hit the a-arm. Lock to lock I have about an inch to spare. I have at least 2 to 3 inches of space at a full turn from the fender. So IMHO go with less backspacing.
Old 01-29-2007, 01:02 PM   #5
jlaird
jlaird's Avatar
why would you want a 10 in front anyway. Most wheel manufacturers that make these stock wheels (non-custom orders) make two widths. Usually they will have a 9.5" or 10" AND a 8" or 8.5".
Old 01-29-2007, 01:05 PM   #6
wannabeburbowner
I am looking at some used wheels, and all 4 are 10" wide. +20mm offset 6.5" backspace
84 GMC K1500 (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
Old 01-29-2007, 01:09 PM   #7
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
That's an awful wide tire to be turning up front. If you want to lay frame, I hope you got some good fab skills. You're going to have to start cutting.....a lot.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-29-2007, 01:25 PM   #8
jlaird
jlaird's Avatar
That's what I figured.
Old 01-29-2007, 04:50 PM   #9
tom coop
tom coop's Avatar
im running 10 inch wide 22 on a 90 suburban but i dont know the backspacing. im bagged and everything clears. running a 305 40 22 tire
tom coop is offline   Reply With Quote
