Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2008, 04:41 AM   #1
Montini
Montini's Avatar
Ran my 72 at the strip
Just got back from the track, truck ran 8.20's in the 1/8th. Tranny is hesitating on 2-3 shift, hit the rev limiter and took way to long to shift. I am hoping on getting in the 7's with no spray. I guess 8.20's isn't too bad without spray. Does anyone know what these trucks weigh? Its a 72 c10 shortbed, all steel.
Montini is offline   Reply With Quote
Old 03-03-2008, 06:59 AM   #2
69trk
69trk's Avatar
Re: Ran my 72 at the strip
I take it it's a small block. Mine weighed around 3715 with a big block. I've taken all the ac stuff, heater core, blower motor and the box for the air from under the dash off.
69trk is offline   Reply With Quote
Old 03-03-2008, 08:14 AM   #3
Couch
Daily Driver
Couch's Avatar
mines a swb small block with a wood floor and no heater box or heat assm. and no bumpers or inner fender wells and with me in it and like 1/2 a tank i weighed 3460.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 03-03-2008, 11:37 AM   #4
Super73
Super73's Avatar
Couch,
That is light.. I would think mine should be lighter being an LS1/4L80E. Last time I weighed it, it was 3,840 with me in it and a full tank. Since then I lost the front bumper (had a roll pan in the rear) put draglites on it, yanked the heater and swapped back to manual brakes.
Your's is still going to be lighter...
Super73 is offline   Reply With Quote
Old 03-03-2008, 01:25 PM   #5
Montini
Montini's Avatar
I'm running a 383 stroker and th400 with no heater box.
Old 03-04-2008, 11:19 AM   #6
Couch
Daily Driver
Couch's Avatar
Originally Posted by Super73 View Post
Couch,
ive been told theres no way its that light at the track.then i bust out the slip that says it. i should upload it into my photobucket just in case, i coulda proved myself on a previous board. by wooden floored bed.its just a piece of plywood. the original wood was shot. so that shed like 50 to 60 lbs. i'd guess
Old 03-04-2008, 06:29 PM   #7
Montini
Montini's Avatar
I'm hoping to get it in the 7's without spray. First I need to find out why the 2-3 shift is hesitating, the aftermarket dipstick is not accurate. When it reads full on this stick it is way overfilled. The pan on it is deeper than any th400 I've seen, it is a stock stamped steel piece. I was told this is a hd version that was put in 3/4 and 1 ton models. I am wondering if the fluid was a little low, would it cause the hesitation? If the fluid was a little high would it foam and cause the hesitation. It is not slipping at all, launches very hard and chirps 2nd but hesitates going to 3rd. Anyone ever had this problem?
Old 03-04-2008, 08:35 AM   #8
djracer
djracer's Avatar
That's a pretty good time!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-05-2008, 08:11 AM   #9
djracer
djracer's Avatar
Pm Sent!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-07-2008, 09:11 AM   #10
Outlaw72
Hay Team!!
Outlaw72's Avatar
8.20's is good for a small block ..
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 03-07-2008, 10:10 AM   #11
LuckyHenriksen
LuckyHenriksen's Avatar
Is there anything special about removing all the heater stuff or is it just unbolt and yank
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 03-07-2008, 05:02 PM   #12
djracer
djracer's Avatar
unbolt yank and make a plate to cover the hole!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-08-2008, 05:55 AM   #13
LuckyHenriksen
Sweet what do you make the plate out of
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 03-08-2008, 06:43 AM   #14
GMC70c20
My old c20 weighted right at 4000 lbs and thats with a small block and a muncie sm465 trans. I think a all stock 1/2 ton weighed about 3700 lbs.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 03-08-2008, 08:34 AM   #15
djracer
djracer's Avatar
I use a thin piece of aluminum!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-08-2008, 07:14 AM   #16
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
That aint a bad time at all. You just need to get that tranny figured out 4 sure. Any luck with it yet?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
