09-01-2008, 01:30 PM | #1 |
Carb problems?????
I am trying to get my new 72 running and ran into a problem. The truck has been sitting for awhile. I can pour gas into the carb and it runs fine til the gas runs out, but then dies. I took of the fuel line at the carb and checked/changed the filter and when I tried to turn over the engine gas shot out of the line. So I guess the problem is in the carb. Is there a simple fix or do I just need to get it rebuilt......Thanks Jason
Here is a pic of the truck by the way.
72 Cheyenne Super 80 Silverado Blazer 2wd |
09-01-2008, 02:10 PM | #2 |
Re: Carb problems?????
Q-Jet??
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-01-2008, 02:21 PM | #3 |
Sounds like your accelerator pump. look into your carb with everything hooked up and push your throttle,look for a squirt of gas. If nothing happens then you need your carb rebuilt.
09-01-2008, 03:11 PM | #4 |
09-01-2008, 03:21 PM | #5 |
newly minted old timer
perhaps your float is stuck in the up position.. smack it will a rubber mallet!! lol redneck rebuild.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
09-01-2008, 04:44 PM | #6 |
With a Q-Jet you know nothing about what has been done or not done I would first check to see if the filter where the fuel line connects to the carb is clogged. If thats alright then check the float and needle valve.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 09-01-2008 at 04:45 PM. |
