12-10-2008, 03:19 PM | #1 |
Wheel spacers
I was wondering if anyone is using wheel spacers on their trucks. I'm looking at purchasing a set of 3" billit spacers to help the rear tires fill the wheel well and centering the rearend. I'll also be using a wider rear tire on the 8" rims. Anyone using spacers?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
12-10-2008, 03:37 PM | #2 |
Yellow truck club
Re: Wheel spacers
I'm running 2.5" spacers on my rear.
2 plus years no trouble. Not a lot of weight on them. I've got about 1/2" between tire and lip. No problems aired up or down.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
12-10-2008, 03:52 PM | #3 |
Re: Wheel spacers
I'm running 3" spacers in the rear as well.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
12-10-2008, 04:03 PM | #4 |
Re: Wheel spacers
Are you guys running the spacers on the 2wd rears or on the 4x one? And did you go with the stock s10 offset rims or switch to a different set?
I'm working on the s10 swap build up on the frame at the moment while I wait to pick up my trucks. Cheers, Ted. |
12-10-2008, 05:04 PM | #5 |
Yellow truck club
Re: Wheel spacers
My rear is a S-10 4 dr 4x4 in my 59.
I'm running 15x7 ralleys with 70 series. I think a set of 2" would have been a better choice 4 my truck.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 12-10-2008 at 05:05 PM. |
12-10-2008, 05:20 PM | #6 |
Re: Wheel spacers
Mine is the 2wd s10 rear with stock s10 rims 14x7's.
12-10-2008, 06:14 PM | #7 |
Re: Wheel spacers
I'm using a Chevy II rear end with 17 x 8 Torq Thrust II's.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 12-10-2008 at 06:19 PM. |
12-10-2008, 06:59 PM | #8 |
Re: Wheel spacers
Gotcha. I'm looking at running the stock S10 backspacing on the 4x4 rear axle...now just to decide whether to go with the 3.42 or 3.08 gears with the 4.3 and 700r4
Cheers, Ted. |
12-10-2008, 10:09 PM | #9 |
Yellow truck club
Re: Wheel spacers
I'd go the 3.42. I'm running a 350 with the 700 r and unless I'm on the hiway I run it in 3rd. Just find the rpm too low around town.
12-10-2008, 11:22 PM | #10 |
Re: Wheel spacers
I'm using 2.5 billit spacers. Been on for two years with no problem. I'm running the same rear as entourageguy, but mine is a 2 wheel drive and his was from a 4 wheel drive, 4x4 is wider then the 2x4.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
