03-25-2009, 10:44 AM | #1 |
profeshinaly unimployed
transmission stop leak
i have a slight leak of transmission fluid from my transfer case and i think i might just put some transmission stop leak in it...what do you guys think good or bad idea
"having mud flaps is like asking for a smaller trophy" |
03-25-2009, 02:27 PM | #2 |
Re: transmission stop leak
I had the same problem, change the gasket and resolve problem, my transmission is a th700r4
03-25-2009, 03:50 PM | #3 |
Robert Olson Transport
If that kind of stuff really worked Aamco would be out of business.. That stuff usually does more harm than good, and frankly i would only use that if i were stuck in some backwood county and heard the drum beats of "Deliverance" approaching as i popped the hood of the truck.
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-25-2009, 04:28 PM | #4 |
if you use anything use lucas what t case do you have. if it is a np208 use lucas trans fluid. if it uses oil use lucas oil additive.just read the bottle and get the one for that kind of lube.
03-25-2009, 04:47 PM | #5 |
I agree. If you are planning a rebuild in the near future, and are just wanting a quick fix then go for it. Other than that I would go ahead and change the gaskets and new fluid.
03-25-2009, 05:44 PM | #6 |
its a np 208
03-26-2009, 03:42 PM | #7 |
x2 on lucas. I'd put it in there even after you fix the leak. But it's thicker and won't go out the leaks as easily. My th400 had a tad of a leaky converter seal and was slipping and I was planning on a tranny rebuild. I put the lucas in and now it doesn't leak, and shifts right with no slipping, so the tranny can be put off for a WHILE. I put the oil stuff in my old 400 before I rebuilt it and it cut my bad main seal leak in half. it makes a good band-aid, but it is just a band-aid if that's what you're using it for.
03-29-2009, 03:43 AM | #8 |
X3 on the Lucas, my 79 was leaking all over the place before i pulled it out, its in the rebuild stage now
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) |
03-29-2009, 07:07 PM | #9 | |
Arrived on a Pale Horse
Back to the question at hand, take the time to fix the leak. Stop leak products have a tendency to plug other orifaces that need not be plugged.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
03-29-2009, 07:25 PM | #10 | |
Old Heap Driver
Kind of like Deliverance.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
03-29-2009, 07:25 PM | #11 |
It was a BANJO not a drum. LOL
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
03-29-2009, 07:33 PM | #12 |
exactly....and the trans will squeal like a pig....
03-29-2009, 07:35 PM | #13 |
Old Heap Driver
......................... Nevermind, this is a family site. LOL!
