Old 06-04-2009, 06:00 PM   #1
Cdshinne
Cdshinne's Avatar
2000 silverado 5.3 starting problem!
my 5.3 has had starting problems for about 20k-30k miles and its getting real old! we have tried relays new fuel pump and fuel filter. I think it is the coils but i want to be sure. What happens is i can turn and hold it for as long as i want and she wont fire, then when i try it a second time she fires up right away. this has been getting worse as the weather heats up. it is starting to take 3 times now! has anyone had this problem or know the solution?
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Cdshinne is offline   Reply With Quote
Old 06-04-2009, 06:44 PM   #2
LEEVON
LEEVON's Avatar
Re: 2000 silverado 5.3 starting problem!
fuel pressure regulator can cause this symptom. it's on the driver's side fuel rail and can be easily replaced for about $60...but to be sure you should have it checked out. One way to check is by pulling the vacuum hose off of it, if fuel comes out then the internal diaphram is ruptured and it's bad.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
