09-01-2009, 06:40 PM | #1 |
Th400 & 205 transfer case what years ?
I am new to the 4x4 world I am putting my 65 chevy on a 77k20 frame. I have a
Th400 2wd trans that I want to use. In my research I found that the some of the 205 figure 8 style transfer cases use the 2wd th400. Does any one know what years of trucks I can find a 205 32 spline transfer case setup for the 2wd th400 ? Thanks. Pick N pull is having a half off sale this weekend so I am hoping to find the right one. |
09-01-2009, 10:33 PM | #2 |
Re: Th400 & 205 transfer case what years ?
Any 32 spline 205 will work with the 2wd TH400 as long as you have the adapter that goes with it.
1949 Five Window, 1973 Step Side, 2000 Z71 |
09-02-2009, 09:10 AM | #3 |
Measure the output shaft sticking out of the tranny. If it's 6.5" then you use the adapter and case off an early 400/205. 84 and older.
All 1980 Gm trucks that are 4wd will have a 205, so find a 3/4 or 1 ton, long as it's an auto. After 80', only 1 tons will have the 400/205. Prior to 80', 3/4 and 1 tons will have it, but can't remember how far back. Think it's only to 77/78.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
09-02-2009, 10:52 AM | #4 |
Advance adapters sells various coupler sleeves to mate the various np205s to various transmissions. For instance I think they sell a 32 spline to 10 spline coupler sleeve.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
09-02-2009, 12:30 PM | #5 |
as long as the adapter is for a 400/205 and it mates to the 205 you have than it will work. so if you are going to a pick-n-pull than just make sure the tranny u pull it from is a 400
09-03-2009, 02:23 PM | #6 |
Good News ! I found a guy selling a 205 for a th400 for $200. I bought it and hooked it up last night. Bolted right up. Thanks for your help.
09-03-2009, 08:06 PM | #7 |
Not a problem, that's why we are here.
09-03-2009, 11:02 PM | #8 |
well I tought I was on the home stretch on this project but It appears that the transfer case sits to lower using the original 205 crossmember. I thought all 205 crossmembers where the same ?? how to I do I get it to sit about 3-4 inches taller ? Is there a different crossmember i need or different mounts ?
Thanks again. |
09-04-2009, 02:10 PM | #9 |
Can't you slide the crossmember you have up the frame, trim the top side flanges and drill new holes? If not maybe a piece of 2, 3 or 4" steel tube with trans mount to fit. Bolt bottom the cross member, top to mount and you are ready to go.
09-04-2009, 06:20 PM | #10 |
Thanks for the help I think that would work for the length but the other problem I have is where the front drive line connect to the transfer case it is to close to the crossmember.. I may just have things jacked up. I'll take picture and post when I can.
09-23-2009, 11:32 PM | #11 |
I had my NP205 machined for the TH400 output, I broke a couple of adapters and now it holds together just fine.
1967 Nova SS LS9 800HP 1965 Malibu SS Convertible F/S 1965 Chevelle 2-Door Wagon F/S 1972 K5 Blazer 5.3 |
09-24-2009, 04:45 AM | #12 |
there are tall and short TH400 adapters, each with its own crossmember. I'm not sure which trucks came with what, but the difference is 2 1/2 - 3 inches.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
09-25-2009, 02:08 AM | #13 | |
All GM light duty trucks with automatic transmission from 1974-1979 had the 203 transfercase as standard equipment. |
