08-17-2010, 04:14 PM | #1 |
1983 - 1986 Chevy Suburban 5.0L 305ci Exhaust Manifold LH
CLICK LINK BELOW FOR CURRENT PRICES.
1983 - 1986 Chevy Suburban 5.0L 305ci Exhaust Manifold LH Our aftermarket manifolds are some of the highest quality replacements on the market! If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement. This cast iron manifold has been designed to eliminate the faults of the original GM design. Designed for use with all emissions and non-emissions vehicles. Specifications LH Driver side 3 bolt flange Replaces dealer part numbers: 14050233, 14079295 Direct replacement Replaces original manifolds that are cracked from thermal expansion and contraction Corrosion resistant Strengthened and redesigned in the vulnerable areas of failure Now you can buy a high quality exhaust manifold that is built to strict quality control standards for less then 1/2 the price at the dealer. REPLACE your broken, warped, or cracked one now with this great fitting, alternative. It is a great replacement and has substantial cost savings over a dealer unit. Backed by manufacturer's limited LIFETIME warranty. For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty. |
