11-09-2010, 09:38 PM | #1 |
Can you help me decifer these codes?
Last couple of weeks I was stressing over what to do about my 305, then I realized I had never actually run the numbers on this motor to see if it really was a 305 as the P.O. said. Well, here's what I've found.
Block - 3970010 - 1968=327/1969-1979=350 (Also found 1 site that said 302 in 69 Camaro Z28) Date code E248 = E for May/ 24 for 24th day / 8 for 19?8 (from this I'm not sure how to tell if it's a 68 block or a 78 block) Heads - 3932441 - one website said 1969-1970 350, one just said 1967-1979 Date code H138 = August 13, 19?8 (??) Valves - 1.94/1.50 76cc chambers As far as the pad on the front under the alt. - I could vaguely see what looked like a vin stamped in it, but it was so slight that I couldn't read it. However, under that was a very clearly stamped TH277. The only thing I can find about that is that the TH prefix was a 1978 305 out of a Firebird. Hmm. Thoughts? Any help is appreciated. Also, how does this affect my cam choice?
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
11-09-2010, 09:47 PM | #2 |
Re: Can you help me decifer these codes?
Theres a 95% chance you have a 350. I would be willing to bet a lot of money its not a 302. It could be a 327 but its most likely a 350.Its definately not a 305. You can now pick a little bit bigger cam. A big cam in a 305 is a mild cam in a 350. most specs for camshafts such at the operating range is based on a 350.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-10-2010, 07:13 AM | #3 |
It is a 350
Tim |
11-10-2010, 08:14 AM | #4 |
The TH277 is more than likely an engine builders stamp. I'm betting it's a 78 block.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
