Frame strength
I haven't been able to find anything on here regarding frame strength. I've got the bare frame laying here and it seems fairly easy to twist. I was wondering if anyone did anything to stiffen them up? Things like welding the crossmembers in or boxing them? I will be doing a full cage so maybe I'm just being paranoid? I am looking to put around 1000 horsepower through it eventually. Any advice would be appreciated.
1983 Jeep Cherokee 2 door LWB '71 C10 frame shortened to 110" wb, turbo HEMI powered, autocross project 1977 Jeep Wagoneer 4 door Looks stock, 83mm Bullseye turbocharged AMC 401 |
Re: Frame strength
At a for real legit 1000 horsepower you need to be looking at doing a full tube chassis. There arent many stock frames capable of handling that without twisting.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#3 | |
![]() Join Date: Mar 2008
Re: Frame strength
NHRA Super Street 469C It only runs 10.90 at 156 mph |
#4 | |
Re: Frame strength
Re: Frame strength
People are putting 1000+ hp through 4th gen f-bods with sub frame connectors and a cage. I'm sure they would pretzel up before one of these truck frames with a cage attached to it.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#6 | |
It's Better With Nitro
Re: Frame strength
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 11-29-2010 at 11:43 AM. |
#7 | |
Re: Frame strength
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: Frame strength
I have a 73 short Stepside. i thoguht the same thing so i boxed out a little over half the frame almost to the trans cross member. after getting about 2 feet boxed on both sides i had almost no flex in the frame. from trying to twist it with my hands. i plan on having a full cage put in after i get it back together. also planning on around 1k HP. Just my two cents.
Re: Frame strength
I welded some of the crossmembers to top and bottom of frame. I am not sure if it was nesc., I was just paranoid. Installed 12 point cage with funnycar cage. Certified to 7.50 with NHRA. I put well over 1000 hp through mine with stock suspension, and have not had any problems yet. Enjoy it, it's a blast to bust off mid-five second runs in the 1/8, and see people's faces after each run. This truck got more people stopping by in the pits after one pass, than our index car has gotten in 4 years! Paul Baxter
Re: Frame strength
im not 100% sure but. you look at a truck frame and look at a nova/camaro frame and there is none then look at the chevelle and cutless frame?
Re: Frame strength
This is true, the X-bodies utilize a subframe configuration, while the A-bodies had a full frame with a rocker kick out design.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
