Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-02-2011, 12:06 AM   #1
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
amp power cable wire guage
Is 10 guage sufficient enough for a 600 watt sony xplod
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 01-04-2011, 07:18 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: amp power cable wire guage
Depends on the distance its being run.
For power to/from the battery, no way. To a pair of subs that are within 6 feet, it will be great.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-05-2011, 11:11 AM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
No, 8 is the smallest I would go, if you can fit it though I'd go with 4 gauge.
ProStreet68SB is offline   Reply With Quote
Old 01-06-2011, 11:29 AM   #4
AceX
>130dB Moderator
AceX's Avatar
On 600watts, 8ga is fine. ANY more though, and I'd definitely go with 4ga.
Living Life @ 130dB
RIP El Jay
Old 01-10-2011, 12:32 AM   #5
getbent
run some welding wire 1/0 jmo good luck
getbent is offline   Reply With Quote
Old 01-10-2011, 02:15 PM   #6
ProStreet68SB
thats overkill for 600watts, especially sonys "600watts".
Old 01-11-2011, 01:31 PM   #7
panhandler62
Java Mechanic
panhandler62's Avatar
If it's a Sony that came from Walmart and says 600 on it... it's probably about 23w rms on each channel.
I have 6g to a terminal block and then 8g to an amp of that description and a to slighly larger MTC. I've had no problems with that and none of the wires ever feel any warmer to the touch than the ambient temp.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
