06-19-2010, 07:46 PM | #1 |
BAD BOW-Silverado XST
R134 condensor
Ready-Aire - Air Conditioning Condenser
Part Number: 636420 I bought a new condensor. Here are the pictures of it. Yes, this condensor is a multiple path (cross) flow condensor designed for R134. Yes, the Orielly's computer lists it as a direct replacement. I guess manufacturers decided to make them for older trucks. Now, I just need time to discharge my current system to install it. Last edited by gchemist; 06-19-2010 at 07:47 PM. |
06-19-2010, 08:06 PM | #2 |
Re: R134 condensor
How well does your air work right now? I've been thinking about doing the same thing with my Burb. It works well except the really hot days, it's just so-so. It could stand to blow out the dash a little faster too.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
06-19-2010, 10:09 PM | #3 |
Re: R134 condensor
Mine works great when the truck is moving. City driving and stop lights are bad. Install some foam pads between the radiator and condensor. Get as much air through the condensor as possible. You can even use padding over the top portion. I'm replacing mine since I run electric fans. My fans are not running all the time. The single tube R12 design can work if you run enough air through the condensor.
If anyone upgrades to R134, consider upgrading the condensor. $119.16 with tax at O'rielly's. |
06-19-2010, 10:24 PM | #4 |
Location: Where I come from, it's cornbread and chicken...
Re: R134 condensor
Will that condensor help with non having cold air at idle. Mines nice and going down the road but when you stop it slowly gets warmer.
06-19-2010, 11:16 PM | #5 |
All About the BOWTIE
Re: R134 condensor
Yeah... My air does the same thing.. cold during driving.. and cool at best during stop and go traffic, with 134a conversion, Really hot days the A/C hangs in there.. IMO.. i think thats the best its gonna get.. with these units
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
06-19-2010, 11:37 PM | #6 |
Re: R134 condensor
What about putting electric fans on there that should pull air through the condensor at idle right?
06-19-2010, 11:43 PM | #7 |
Gettin It One Pice At A Time
Re: R134 condensor
That is what a modern day car does. When the ac is turned on the fan comes on.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
06-19-2010, 11:51 PM | #8 |
Re: R134 condensor
That's what I'm saying so my can't it work on our trucks?
06-20-2010, 12:18 AM | #9 |
Re: R134 condensor
Close up all the open areas around the condensor. If anyone is running a mechanical fan, you'll notice the difference at idle and stop and go traffic. Cooling will be better. A mechanical fan, above condensor, and sealed areas are the best you can do for a stock system. The only other best upgrade is a Sayden compressor.
06-20-2010, 12:27 AM | #10 |
Re: R134 condensor
If it's not working well at idle, replace the fan clutch. If you have electric fans, they NEED to be on when the AC is on. Some fan controllers have an AC input wire so the fans automatically come on (it needs wired in, of course).
06-20-2010, 01:01 AM | #11 |
Re: R134 condensor
I wonder if the 73-80 condensers will be available in the newer design? I am sure the newer style condensor will make an incredible difference in the vent temps.
Frank
Born and proudly residing in a Red State ! |
06-20-2010, 03:02 AM | #12 |
Re: R134 condensor
If you do get electric fan you will go on when your A/C is on so that should shove your problem with warm air at stop lights..
06-20-2010, 05:30 AM | #13 |
Re: R134 condensor
Even if the clutch is replaced, a stock R12 condensor has its limitations. R12 and R134 condensors are different. R12 has a single tube that runs back and forth. A R134 condensor has a parallel flow path. Freon travels in multiple paths to help transfer heat.
06-20-2010, 11:53 AM | #14 |
Re: R134 condensor
Yes, I was just pointing out that if the AC is turned on, there needs to be good air flow while stopped. It is very important that the electric fan comes on with the AC on. Without it, not only will the AC not blow cold, but it will build up excessive pressure and shorten the life of the compressor.
06-20-2010, 11:20 PM | #15 |
IT Guy/ Father/ Chevy lover
Re: R134 condensor
Fat hoe I was thinking the same thing reading through the thread I don't imagine it would be hard to install an electric fan and a switch under the dash. I'm going to have to remember this when I go after my ac replacement
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
06-21-2010, 11:10 AM | #16 |
On a budget like Fred Sanford
Re: R134 condensor
Awesome find gchemist!!! I've been wishing for a cross flow condenser for years.......
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
06-21-2010, 11:41 AM | #17 |
Re: R134 condensor
Of course, this comes 4 days after I charge my A/C, go figure! :P
06-21-2010, 12:33 PM | #18 |
Insert Witty Text Here
Re: R134 condensor
06-21-2010, 01:08 PM | #19 | |
Re: R134 condensor
Maybe this link will work... http://www.oreillyauto.com/site/c/de...2669&ppt=C0355 This is what it says... Ready-Aire - AC Condenser Part Number: 636120 Line: TPR * UPC: 40876361201 * Not eligible for free shipping Warranty Info Limited Lifetime Warranty Brand Information Proliance's Ready-Aire® A/C Condensers offer a full line program with over 450 models covering over 95% of the light duty vehicles on the road today. * All aluminum construction assures long-life durability and offers the latest technology with the following construction types: o Parallel flow o 6mm expanded tube o Serpentine * Advanced CAD design for optimal configurations to produce precision products from design through final manufacturing. * Mounting holes and brackets line up every time to allow drop-in installation. * All condensers meet or exceed OE specifications for A/C performance and durability. Slonaker |
06-23-2010, 01:26 AM | #20 |
Re: R134 condensor
It's 6mm. As far as I know they do not make a true parallel flow condenser for these trucks. Probably never will.
Troy 1982 Silverado |
06-23-2010, 05:34 PM | #21 |
Re: R134 condensor
I agree. The new condensor is a little improvement over the R12 condensor.
06-29-2010, 04:05 PM | #22 |
Re: R134 condensor
Please post back with results.Looking into swapping out my condensor also.Thanks
06-29-2010, 07:12 PM | #23 |
Re: R134 condensor
It may be a few more weeks before I have a chance to install it. Either way, the condensor is an improvement. I recommend the upgrade for a R134 conversion.
06-29-2010, 10:03 PM | #24 |
Re: R134 condensor
I've had this type condenser in my truck over four years now. It's pretty much what you will get if you buy from any of the big part store. I've done all the tweaks you can think of, from sealing the gaps to the E fan etc. Every bit helps. It is better the the 3/8 tube condenser. The bad thing is the condenser in these trucks are small. If they were bigger it would really work good. You still should see an improvement if everything is done right. I still have the R4 which I hate. The only reason I didn't change to a Sanden & true parallel condenser is I want to keep the factory look. Except for the E fan of course.
Troy 1982 Silverado Last edited by Troy 82; 06-30-2010 at 05:09 PM. |
06-30-2010, 10:17 AM | #25 |
BMW & ASE Master Certified
Re: R134 condensor
i have the stock condensor and evap in the truck. orielly orfice tube and accumulator, stock 5.3 compressor and after i put the fan shroud on the truck the vent temps are at 50* after 5 mintues of driiving. charged the system to 1.85ish lbs and the pressures were at 28-35low and 200-220 on the high. good enough in my book. I had it at 1.75lbs but the compressor would cycle at idle.. added the extra .1 and it doesnt cycle as much and the high side pressures only went up like 5psi..
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
