Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Closed Thread
Old 01-22-2011, 10:41 PM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
73-87 2wd lift with 33x10.5x 18 Nittos
To discuss this topic go here-"2wd lift and new 18's w/ 33x10.5 Nittos"
18x8" Chevy 6 lugs wheels off a new Z71, Nitto Terragrappler 33x10.5. Rear 2.5" Rancho lift blocks with Bilstein 5100 extended shocks. The front has 88-98 Rough Country lift spindles. I'm using the Moog 6454 HD springs. I will have to see if I can get it aligned with them, but the tops of the tires are angled out some. May have to put in shorter springs to get the correct camber. Here's how it looks so far.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline
Old 02-07-2011, 11:15 PM   #2
Justins76
Justins76's Avatar
Nitto Terragrappler 33x10.50
Front-
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Belltech 1 3/8" sway bar
73-87 C30 lower A-arm
73-87 C10 upper A-arm
One problem I ran into was the 88-98 outer tie rods connect to the spindle from underneath and caused interference with the sway bar. I do not know if this would be a problem with the stock sway bar. Since the tie rod joint is smaller then a 73-87, what I did was get a taper reamer from summit and reamed it from above and used the stock tie rod.
The brake hoses are from a 88-98 and they connect to the frame differently. If you clock them just right, they will fit into the hole in the frame and use a horseshoe shaped clip to hold it in.
The spindle, rotors, bearings, calipers, pads, ball joints and hoses I used were from a 1994. The rest is stock 73-87 parts, with 1 ton lower control arms.
You have to use 88-98 rotors and calipers. Since the 88-98 ball joint is bigger, it wont fit 1/2 ton arms. I'm using 88-98 Raybestos PG (formerly Spicer) ball joints.
My cardomain page
Old 02-07-2011, 11:15 PM   #3
Justins76
Justins76's Avatar
For the rear I used blocks and longer shocks with 4wd axles since I'm using 6 lug wheels.
Rear
Rancho 2.5"lift blocks
My cardomain page
Old 02-09-2011, 01:37 AM   #4
Justins76
Justins76's Avatar
I am currently working on a spreadsheet with all the part numbers. I will also be posting pics with height dimensions.
Click image for full size view(last update 2/14/11)
My cardomain page
Old 02-15-2011, 12:11 AM   #5
Justins76
Justins76's Avatar
Got it aligned. They used almost no shims but got it in spec. I had to change how the brake hose attached to the control arm because it was pulling tight on turns. Also had to trim the fender at the front because of the tread rubbing going over bumps with the wheels turned. With my digital level, I get about .1-.2° angle down in the front. Ride is smooth on the freeway and curbs are easier to hop
Some dimensions with a tape measure.
My cardomain page
Closed Thread
