Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-27-2016, 08:50 PM   #1
stevenbear72
stevenbear72's Avatar
Exclamation 70 k20 3/4 ton build "Shirley"
Howdy from Texas ya'll
I have been a member of this forum for some time now, I have a 68 c10 that I'm slowly, but surely restoring.
I recently (Feb 2016') had the pleasure of buying a 1970 Chevrolet K20 3/4 ton 4x4, with a hydraulic flatbed from a coworker. The truck was purchased with a tired out 350 motor that had leaks from every possible seam. The truck was not drivable when he sold it to me, but I took a leap of faith and bought it anyway.
I proceeded to have to truck taken to a small hot rod shop in the city that I work in called Freer, Texas. There the truck was to undergo a heart transplant as well as other minor things here and there to get here road worthy.
I decided to name her Shirley.
This is her with some jeep wheels and 37" tires that the previous owner tried pulling off, looked cool, but rubbed too much and motor and trans didn't move them well enough, clutch was toast and flywheel was all heat spotted.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 06-27-2016, 08:59 PM   #2
stevenbear72
Re: 70 k20 3/4 ton build "Shirley"
Here is how she looked when I got her, and a pic of her build sheet.
Old 06-27-2016, 10:53 PM   #3
dozerbill72
dozerbill72's Avatar
Congrats, thats a very cool rig. But I have to ask what are "jeep" wheels?
dozerbill72 is offline   Reply With Quote
Old 06-27-2016, 11:51 PM   #4
stevenbear72
wheels he bought off a jeep, haha
Old 06-28-2016, 09:53 AM   #5
7dee2
7dee2's Avatar
Shirley looks like a peach to me! Nice score stevenbear72!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 07-03-2016, 04:58 PM   #6
stevenbear72
Thanks bud, here are some more pics of the build process.
So this was the tired out 350 that came in the truck.
and how nice and leaky she looked once removed
Old 07-05-2016, 07:59 PM   #7
stevenbear72
Well that's not supposed to look like that...
Getting started on the fresh 454 engine rebuild, keeping the standard bore. Slapping in a nice choppy Comp Thumper cam.
Speed Pro Hypereutetic pistons
All new clevite bearings
New speed pro piston rings
Comp cams double roller timing chain
Old 07-07-2016, 08:22 PM   #8
swamp rat
swamp rat's Avatar
Nice truck and lift bed! gonna be a whole lot nicer with a rebuild and new clutch!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-09-2016, 09:52 AM   #9
7dee2
7dee2's Avatar
Ha, the small block had some nice crud going on reminds me of my blue c30!
A 454 just made Shirley even peachier she's a burly girl!
Brett
Old 08-27-2016, 03:03 PM   #10
stevenbear72
Apologies for not updating sooner, been swamped with working night shift, I'm back to working day shift and no longer being a zombie.
With that being said, here are some more parts that I've gathered for my build.
Soaked the Comp lifters for a few days while we worked on other things for the build
Ordered some nice longtube Hedman hedders, which will be heat wrapped later
New Duralast waterpump
Preppin' to install pistons and rods
Comp Cams Thumper cam that's going into motor
Old 09-06-2016, 12:52 PM   #11
stevenbear72
Forgot to add the photo of the Mellings high volume oil pump.
Cam going in
Here you can see the dual springs and new valve seals that were added to the heads
Prepping the motor for paint
Here she is freshly painted.
My buddy decided to paint the intake Silver and add a clear coat to the Edelbrock intake. The carb ill be running is a 650 dual feed Holley that I had laying around. Fresh carb rebuild on it as well.
Old 09-06-2016, 01:21 PM   #12
stevenbear72
Received some more goodies for Shirley. New flywheel, pressure plate, & clutch.
New cap and rotor
New high volume Delphi fuel pump, buddy said he orders it from a 69 Impala with the 427 at parts store.
New tach
Fan relay kit
hedder wrap
New duralast motor mounts
New spark plug wiring set
New gauges
New starter
Old 09-06-2016, 01:38 PM   #13
stevenbear72
New Optima battery, these things are freaking expensive!
New Champion 3 row radiator
Old 09-13-2016, 09:57 AM   #14
7dee2
7dee2's Avatar
Nice parts, can't wait to hear it run!
Brett
Old 09-23-2016, 10:19 PM   #15
swamp rat
swamp rat's Avatar
Lots of goodies and coming together nicely!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-06-2016, 07:47 PM   #16
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man, Shirley is a real nice and clean K20. That dump bed is a nice treat too. Nice work on that 454. Do those headers fit a 2wd car or are they for a BBC in a 67-72 4wd?
Ryan
1969 Chevy milk truck
Old 11-30-2016, 06:05 PM   #17
First c10
First c10's Avatar
I used this radiator on my sons truck. if it has the aluminum fan shroud with the 2 electric fan option, make sure the fan shroud does NOT touch the fins of the radiator. On mine it barely touched one tube and wore a hole in it after some time and I had to disassemble and weld it up. What a pain in the arse. On the Hulk Build I made sure to trim it!
Good looking build!
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-01-2016, 04:38 PM   #18
Yukon Jack
Yukon Jack's Avatar
Great looking project!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-03-2016, 11:50 AM   #19
ryanroo
ryanroo's Avatar
cant go wrong with a 454 in a k20! looking good!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
