07-16-2012, 09:09 AM | #1 |
Critique my brake flares
Posted this over in the '47-'59 forum also...
This weekend I tried my hand in flaring brake lines. I have never done this before so I did quite a bit of reading and making sure I followed everything properly. I have a good set of flaring tools (MAC Tools) so quality of tools wasn't a worry. I started with cutting my lines and trying to keep them square a possible. I used a file to clean up the edges and the outside of the tube just a bit. I then deberred in the inside of the line with a drill bit. After that I measured the appropriate amount of tube length to leave exposed (measured with the adapter), I then dabbed a little brake fluid on the end (recommended by someone) and then squared up the adapter with the tube. I started my first bubble, took off the adapter, and then flared the end of it. Here is a couple of the flares. I am looking for feedback. I don't think they look that great and would like any recommendations on my technique. I look at my picture and then look at "great flares" and I am doing something wrong haha. Thanks.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
07-16-2012, 10:31 AM | #2 |
Re: Critique my brake flares
If it doesn't leak then it's a good flare, lol. Looks good. Be sure to blow the lines out with air before you install to get the bits of grit out. Good job.
07-16-2012, 12:25 PM | #3 |
67-72 parts collector,…
Don't forget to put the nut on.
I've ruined perfectly bent brake lines, by not adding the nut before that last flare.
07-16-2012, 01:19 PM | #4 | |
Ha I could imagine. Easy to forget them.
