Old 11-07-2012, 03:43 PM   #1
usnabill
usnabill's Avatar
Turn Signal Switch
What is the difference between a 1963 turn signal switch and a 1964-66 switch? I have a 63 column in a 66 truck and need to replace the switch. I do not currently have reverse lights, but want the ability to add them later if I choose. Not sure if that logic is routed through the switch. Thanks.
usnabill is offline   Reply With Quote
Old 11-07-2012, 03:59 PM   #2
1963c-10
1963c-10's Avatar
Re: Turn Signal Switch
I believe the reverse lights were activated by a neutral safety switch that the shift rods engaged when placed in neutral.
1964 Short bed trailer
Old 11-07-2012, 04:04 PM   #3
1963c-10
1963c-10's Avatar
heres some illustration to help
Old 11-07-2012, 09:08 PM   #4
usnabill
usnabill's Avatar
Wow, that's a great diagram. Thank you.
column, lights, switch, turn signal
