Old 02-08-2020, 11:11 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Looking for this part.....
I cant find these anywhere. It is like a button that holds the cowl panel to the cab on the outside edges of the cowl panel. Does anyone know a GM part number, or where I can get these? Mine are broken, but I’ll attach a few pics for reference.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 02-15-2020, 01:05 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Looking for this part.....
I think Classic Parts or LMC use to have them. If not try recycling/scrap yard.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-15-2020, 03:12 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
LMC doesnt appear to carry them, I will check classic parts.
Anybody know the GM part number for this piece? Would really help with cross referencing.
TIA!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 02-19-2020, 12:36 PM   #4
rustprimer
Have you tried rpmparts.ca in Saskatchewan or billstruckshop.com in Ontario.
Joe
rustprimer is offline   Reply With Quote
