02-14-2013, 02:04 PM | #1 |
need some info on lowering
i have a 83 chevy. i want to lower my truck, it already has 2 inch DJM coils in the front. The back has only 2 leaf spring thats how i got truck. i have look and look. what is a good drop for a daily driver truck ahd hauling stuff. i'm thinking of going with 3/5 or 4/5. can you give some info what are best brand to lower my truck. here some pictures as you can see the back lower then the front.
02-14-2013, 03:09 PM | #2 |
Re: need some info on lowering
Are they drop leafs or did someone just remove a bunch? If they are just removed I would start by putting the correct number of leafs in.
02-14-2013, 04:56 PM | #3 |
02-14-2013, 05:33 PM | #4 |
best bet, I'm looking to do a 3/5 myself, as far as brands there's western chassis, belltech, and 1 other brand that I can't remember off the top of my head.
Most everyone goes with western chassis or belltech 2 very good quality brands. if you just have leaf springs in the back do a flip kit in the rear, and for the front just depends on what you want to do most people will do a 2" drop spindle and 1" drop spring. Hope it helps you out.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
02-14-2013, 06:04 PM | #5 |
For a daily driver,in the front I'd use drop spindles, probably a 2 inch spindle, and shackles and hangers in the rear. That should give you about a 4/5 drop.
I have Belltech spindles, they seem pretty well built. Anything from Belltech and Mgaughys is going to be good, I have no experience with Western Chassis, so I can't say.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
02-14-2013, 06:06 PM | #6 |
How many leafs is a C10 supposed to have? Mine has 4.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
02-14-2013, 06:12 PM | #7 | |
02-14-2013, 06:15 PM | #8 |
DJM from what I hear is a pretty reputable company.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp Last edited by maxxxy; 02-14-2013 at 06:22 PM. |
02-14-2013, 06:20 PM | #9 |
02-14-2013, 06:22 PM | #10 |
If it were me, I'd add the correct number of springs in the rear first, because you wont be able to hardly put anything in the bed. Unless you are going to be using helper bags in the rear. In that case, you're fine how you are now.
02-14-2013, 06:25 PM | #11 |
What is the correct number of springs? Not trying to hi-jack. This may be useful to the OP as well as myself.
02-14-2013, 06:28 PM | #12 |
How are the roads in your area? Bad roads = nor much drop. Smoother the roads = the more drop you aan use on a daily driver. Not to mention....How much towing or carrying of heavy loads do you do? The less you carry means the lower you can go without having to do extra work (like a frame notch for rear axle clearance)/buy extra stuff (like air helper springs).
02-14-2013, 06:28 PM | #13 |
I don't have my truck dropped just yet but from what I hear most people will tell you to stay away from DJM, most guys will say Belltech, Western Chassis, or McGaughy's are 3 of the best to buy, everyone will have there own opinion though.
02-14-2013, 06:28 PM | #14 |
i really dont put anything heavy on the bed. i use to load my 4wheeler on bed. but i got trailer for that now.
02-14-2013, 06:31 PM | #15 | |
It just depends on the truck, I know for my 77 I have a total 4 leafs on each side totaling in 8 when combined so does my friends 76.
02-14-2013, 06:34 PM | #16 |
Cali2Texas, also whats your tire/rim combo your running or planning to run?
02-14-2013, 06:42 PM | #17 |
02-14-2013, 06:44 PM | #18 | |
From what I can tell, the stock 2wd 1/2 ton comes in either 4 or 5 springs. Unless you're carring feathers, if you want to use the truck at all like a truck, id suggest increasing number of springs.
02-14-2013, 06:47 PM | #19 | |
02-14-2013, 06:49 PM | #20 | |
In my honest opinion given what your going to be doing I know it might be hard but I would say hold off on dropping it for now, wait to put the 20's on there cause when you put the 20's you could do a static drop and be fine. I met a boardmember on here named DaddyO he hasa static drop on his and he uses his truck to do errands haul stuff simple truck duties. Again though its my advice not saying you have to listen but I'd hate for you to drop it and then mess up your truck you know?
02-14-2013, 06:56 PM | #21 |
2 leaves arent going to haul much!!
02-14-2013, 07:08 PM | #22 |
thanks everyone for the great info, now i know what i need to do.
02-14-2013, 09:23 PM | #23 |
My shorty step side '78 straight six, three on the tree C10 had fo'
02-14-2013, 09:59 PM | #24 |
I've got 8! But mines 3/4 ton. When I do my shackle hanger install I am going to 5.
02-14-2013, 10:38 PM | #25 |
halfs could be 3,5 and 8. not including the overload of course
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
