Old 12-22-2015, 08:45 PM   #1
jakesblazer
Can anyone tell me where the pink wire goes?
Hi there, I have a 72' blazer c10 with the inline 6, 250ci. There are 2 cut wires under the hood! Just wondering if someone can tell me where they belong. It's the pink and green ones. Any help would be great!!
jakesblazer is offline   Reply With Quote
Old 12-23-2015, 02:37 PM   #2
cleszkie
cleszkie's Avatar
Re: Can anyone tell me where the pink wire goes?
Don't quote me on this, but the green wire goes to the temperature sending unit on my SB 350, and the pink wire goes to the ceramic resistor block that is in line and upstream of the coil (if you are still running points ignition). I hope that is accurate, but I'm sure someone will correct me if I'm wrong.
cleszkie is offline   Reply With Quote
Old 12-23-2015, 03:11 PM   #3
jakesblazer
Thanks. The wire that is c goingto the coil has no resistor or ceramic. It Iit a small pink wire that splits into two yellow ones. One to the starter and one to the coil. I am in the process of ordering an HEI distributor so I don't even know if I will need the pink wire?. Any more info will be greatly appreciated! Thanks!
Old 12-23-2015, 03:21 PM   #4
hemi43
hemi43's Avatar
The pink wire is an ignition wire (+12 on run and start) this is the wire that will power your HEI. If you were still running points then this would go to the ballast resistor(if used) or the coil+.
hemi43 is offline   Reply With Quote
Old 12-23-2015, 05:08 PM   #5
1tuff71
1tuff71's Avatar
2x on what hemi43 said if you have a hei and the green one is for temp sender. If you type in wiring diagram on the search tab you can find a complete diagram
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 12-23-2015, 05:33 PM   #6
jakesblazer
The smaller gauge pink wire splits into 2 yellow going to the starter and the coil. Is this the one you say is an ignition wire? The fat pink one is ignition also? The truck. has ran without this fat pink one hooked up anywhere. Just don't want to overlook it.
this pic is taken near the starter. (Down screen the green and pink are cut).
thanks
Old 12-23-2015, 06:00 PM   #7
GMC-YA68
GMC-YA68's Avatar
is the one that is cut have 12v constant to it? check it with a test light.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 12-23-2015, 06:06 PM   #8
hemi43
hemi43's Avatar
Like I said, it's just an ignition wire so it's +12v when in run and start. This can be used to power your HEI or any other accessory. Most pink wires on GMs are ignition .
Old 12-23-2015, 06:17 PM   #9
60case
green temp sender pink anti diesel solenoid
60case is offline   Reply With Quote
