Old 11-28-2013, 10:49 PM   #1
desertnick69
desertnick69's Avatar
which rearend is better
I have two C-20's, one a 1969, the other is a 1970. The 1969 has coils with the round 14 bolt "corperate" rearend, the 1970 has a 14 bolt also but is not round. which is better, stronger? THe top pic is what the 69 has but with coil spring
desertnick69 is offline   Reply With Quote
Old 11-29-2013, 05:58 AM   #2
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Re: which rearend is better
12 bolt hands down. Stronger axles and better and cheaper parts availability with good aftermarket support which is lacking for the old eaton unit.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 12-02-2013, 02:59 AM   #3
andrewmp6
The left one is a eaton rear end has almost no aftermarket for it,The right picture i can't tell with out seeing the whole diff cover it could be a dana 60 not sure.Really any rear end other then that eaton will have a good aftermarket to be built as strong as you want it to be.
Old 12-02-2013, 07:59 AM   #4
ERASER5
ERASER5's Avatar
Little know fact. Almost all of the 14 bolt parts can be swapped into an Eaton HO52. There is a thread on it with the what fits and what needs adapted, and what looks like it won't, but does.
Eatons are about as strong as it gets, but the Gov Lock leave something to be desired.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
