Old 01-14-2014, 07:34 PM   #1
bigcowl-imp
bigcowl-imp's Avatar
What back spacing on wide rear rims....
Just picked up a 64 chevy short fleetside and it came with the fat wheel tubs and i checked and i have 16 inches of tire clearance......I`m thinking a 15x12 rim with 7 or 8 inch back spacing maybe ????
The rim thats on there now is a 15x8 or 8 1/2 wide.....with a 5 inch back spacing..and i have 6 inches of clearance on the inside and about 1 1/2 clearance on the outside......sectional width on the tire is 10 inches...
So watcha think and thank you for any help...
bigcowl-imp is offline   Reply With Quote
Old 01-14-2014, 09:17 PM   #2
PGSigns
PGSigns's Avatar
Re: What back spacing on wide rear rims....
Rim back spacing will also have to be worked out with the tire you decide on. Tire with a fat side wall will need more back spacing.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-15-2014, 08:49 AM   #3
bigcowl-imp
ya i know thats why i`m thinking a 12-13 inch wide rim with about a 14 inch wide treaded tire.....thank you.
Old 01-15-2014, 09:15 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Be careful since tread width measurement specification may be the same or close from tire to tire in the same size and series, etc., the section width of tires in the same size and series vary greatly...I believe that was the point PGSigns was making. So, it is the section width of the tire you want to pay most attention to in your selection to determine backspacing, etc.
Something like this will help: http://www.summitracing.com/parts/PHP-01201/
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-15-2014, 10:36 AM   #5
geezer#99
geezer#99's Avatar
Here's a handy link on how to measure for what fits.
http://www.carcraft.com/techarticles...t/viewall.html
Old 01-15-2014, 01:22 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
This early pic showing my truck with 8.5 / 15 rims with 275/60/15 on all four corners, the rear had just about one finger width from fender lip to tire, lip was not rolled, about two inches from inside fender well, rims have 4.5 inch back space. Stock rear axle 6 lug.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
