08-06-2014, 11:08 PM | #1 |
Lsx ac ?
I read a bunch of pages . I even asked before lol. I would just like a list of parts needed to get an AC going with a swap .
I have an 2012 5.3 . Looking for a list of stuff that I will need this going . Thank you Side note any one running an LSX use an Vintage air kit .
1969 C20 CUSTOM "RUMBLEr" |
08-07-2014, 06:43 AM | #2 |
Old member
Re: Lsx ac ?
No differant than for any other motor. You will need all the parts and just hook it up like factory. That's how mine is and it works fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-07-2014, 10:28 AM | #3 | |
Re: Lsx ac ?
The system includes: •(1) Drive Belt p/n 809-12626222 •(1) Idler Pulley w/Bolt p/n 809-12580771 •(1) Alternator p/n 809-20989651 •(2) Alternator Bolts p/n 809-11516360 •(1) P/S Pump p/n 809-20756714 •(1) P/S Brace p/n 809-12554032 •(2) P/S Brace Nuts p/n 809-11514597 •(1) P/S Brace Bolt p/n 809-11515764 •(1) P/S Pump Pulley p/n 809-12604004 •(3) Stg Pump Mtg Bolt p/n 809-11515767 •(1) Bolt 3/8''-16 p/n 809-19257882 •(1) Nut 3/8''-16 p/n 809-19440957 •(1) Washer p/n 809-19258317 •Power Steering Pump Pulley Install Tool (Included) NOTE: This kit is designed to include the necessary parts to install the complete kit on a Chevrolet Performance 5.3L Crate Engine. If you do not have a Chevrolet Performance 5.3L Crate Engine, you may need some additional hardware. The following parts are included with the Chevrolet Performance 5.3L Crate Engine and are not part of this kit: •(2) Bolt, Tensioner p/n 809-11518633 •(1) Tensioner p/n 809-12609719 •(1) Bracket, Steering/Generator p/n 809-12554030 •(4) Bolt, Bracket p/n 809-11516744 •(1) Balancer p/n 809-12634105 •(1) Bolt, Balancer p/n 809-12557840 •(1) Kit, Water Pump (includes gaskets) p/n 809-12600767 •(6) Bolt, Water Pump p/n 809-12551926 •LC9 5.3L Accesory Drive System without A/C •Fits 5.3L Crate Engine Most of us don't mind helping someone out but finding this took all of 15 seconds. Perhaps you should try doing a little research instead of asking somebody here to run errands for you. |
