Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-20-2018, 08:22 PM   #1
CANUCIT
CANUCIT's Avatar
1962 Back half
Whatcha think ?
I don't know if i should put on the weld center caps
And the disc brakes just barely fit
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline   Reply With Quote
Old 02-21-2018, 05:37 PM   #2
tinydb84
tinydb84's Avatar
Re: 1962 Back half
Very nice
David
Instagram: myfabguy
Old 03-26-2018, 09:43 PM   #3
c10-72 II
Active Member
c10-72 II's Avatar
Re: 1962 Back half
What kit did you use? I’d like to back half my 72
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 03-27-2018, 10:18 AM   #4
CANUCIT
CANUCIT's Avatar
Re: 1962 Back half
Checkered racing Back half, and mosier 9 inch center section and axles
2015 z71
1967 SS Chevelle
Old 03-27-2018, 10:34 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 1962 Back half
If you don't wanna weld on end caps you can order end caps for Workout Equipment. It uses the normal 2x3 tube and just has a press-in black plastic end cap. I did that so I could access wiring that I ran through my frame tubes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-02-2018, 10:45 AM   #6
CANUCIT
CANUCIT's Avatar
Re: 1962 Back half
Put the bed on, and went to remove my fat tires to install longer lug nuts, and couldn't get the tire off, because the bed is too low
Had to raise the back 3 inches to be able to remove the tires ha
2015 z71
1967 SS Chevelle
Old 04-02-2018, 11:01 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 1962 Back half
Hahaha yea that'll happen. Mine does the same. Can't get the wheels off unless my jack is ALL the way up.
