Old 09-27-2017, 07:08 PM   #1
tate65
Parking brake assembly 73-87 (80) C20
Ok the kids 80 C20 failed inspection because the parking brake will not stay on. Tried several things, finally determined its the set pawl on the assembly the tooth is basically gone. (it was a forest service truck I guess they used it a lot), I was hoping it was just the spring but nope. Anyway I can't find just that part, or for that matter a whole new assembly. I may be looking in all the wrong places. I've found older and newer ones but not the 73-87? What's the part number? Who has them?
Considering "welding" a new tooth and filing as a last resort.
tate65 is offline   Reply With Quote
Old 09-28-2017, 12:12 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Parking brake assembly 73-87 (80) C20
Classic Parts # 29-715 73-91 parking Brake Pedal Assembly (Parking brake foot lever assembly)
They should still have them. This was in Vol 17 book few year old now $49.95
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-28-2017, 07:24 AM   #3
tate65
Nope no longer available.
Old 09-28-2017, 07:44 AM   #4
homemade87
I have a vehicle that the same thing happened to . I ordered a new one and it was junk ( failed ) . I took the old one and a file and filed the notches back in the pawl and cleaned up the other part as well . It has worked perfect for a long time .
If you can not find one I would give it a try . It would at least get you past the inspection . When I did mine it was a good solid fix .
You might throw some pictures up to see how bad it is .
homemade87 is offline   Reply With Quote
Old 09-28-2017, 08:42 AM   #5
Jeff's bowtie's
I have a 75 C/10 with one in I'm parting out that works fine if your interested let me know
Jeff's bowtie's is offline   Reply With Quote
Old 09-28-2017, 09:45 AM   #6
tate65
Thanks guys I'll get some photos and I have an offer of a couple take offs. It was pouring last night so no work. That and I try and make him do most of the work and right now homework is taking hours. Sometimes he hates because it's not getting done, but some day...I hope...he will appreciate it. I know I thank my dad every day.
Old 09-28-2017, 05:02 PM   #7
4x4k30
4x4k30's Avatar
looks like this? pm sent 2
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 09-28-2017, 05:12 PM   #8
4x4k30
4x4k30's Avatar
maybe
Old 09-28-2017, 05:39 PM   #9
tate65
Looks right....still raining so can't pull his again
