09-03-2015, 06:54 PM | #1 |
stick to auto swap
Hey guys,this has probably been covered before ,Im planning on putting a 700r4 in my 65 shortbed stepside, that now is a 327 with muncie 318 3speed stick ,373 rear end.I have a 65 c10 auto cross member, gona run a ididit colum,lokar shifter and kick down,what else do I need? any replys thoughts are welcome! anybody done this lately? what would be best converter, its a stock cam and 2bbl single exhaust Thanks cv65
09-03-2015, 11:47 PM | #2 |
Re: stick to auto swap
You will need these parts as well.
auto flex plate auto starter radiator with trans fluid cooler torque converter lockup kit you will need to have the drive shaft shortened correct drive and driven gears for trans so speedometer works correctly
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
09-04-2015, 12:00 AM | #3 | |
Thanks for reply, just rounding up parts now,now I know what to look for |
09-04-2015, 12:12 AM | #4 |
I think the 700R4 crossmember bolt holes are father rearward than on your stock auto crossmember.
Make or buy trans cooler hard lines Proper TV cable and carb bracket. Set-up is critical! Dipstick & housing and a way to mount the housing to the engine T/C dust cover Modulator connection to manifold vacuum source Back-up light switch Park/Neutral safety switch Your stock 2bbl engine will work best with a stock lock-up T/C. Transtar is a good source. See page 24 here: http://www.transtar1.com/download.as...talog_2012.pdf I bought a TH350 (non-lock-up) T/C from them for approx $65 exchange. It has a 4-year/48,000 mile warranty.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-04-2015, 12:39 AM | #5 | |
09-04-2015, 08:11 AM | #6 |
Also you will have to shorten the drive line.
09-04-2015, 11:00 AM | #7 |
Glad I could help.
