Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-29-2014, 12:31 AM   #1
gmachinz
1981-86 reproduction engine harnesses NEW!
If anybody is looking to replace their frayed, scabbed or missing engine harness, I have OEM style harnesses to make your electrical life a little easier.
These are complete from the bulkhead connector forward and come with all connectors needed to retain your HEI or electric choke. Harnesses can be built to your specifications a in most cases at no added costs like aftermarket distributors, non-Qjet electric choke, etc.
All wiring is j1128 spec'd and is rated for under hood use. All terminations are crimped AND soldered and where applicable include flame resistant loom. All stock replacement harnesses can be upgraded with options like HD 4ga charging system upgrade, serpentine swap or even fender mounted washer pump. Price for basic stock replacement engine harness is 139.99 plus shipping.
gmachinz is offline   Reply With Quote
Old 12-30-2014, 07:28 PM   #2
CreditGod
Re: 1981-86 reproduction engine harnesses NEW!
that is a good deal. Why is your electric window harness more money with way less connectors? Is it the parts? I mean 139.00 for a complete engine harness versus 159 for a window harness. Not bashing just trying to understand.
CreditGod is offline   Reply With Quote
Old 12-30-2014, 08:04 PM   #3
gmachinz
The window and lack harnesses both have obsolete connectors and far more wiring. And, the terminals for the window/lock switches aren't cheap either. There's also considerable more soldering required too.I also upgrade the window/lock harnesses for adrasion resistant wrap vs. OEM tape-backed foam.
Old 12-31-2014, 10:13 AM   #4
DownLowHoe
DownLowHoe's Avatar
Do you have these for 73-80 trucks?
DownLowHoe is offline   Reply With Quote
Old 12-31-2014, 11:03 AM   #5
gmachinz
I'm working on those now and should have them ready in a week or two. Color codes are slightly different as is the bulkhead and position of the firewall mounted common 12V junction block. But, soon I'll have them ready to go-along with 73-80 front lighting harnesses...and those will be available with relay upgrade and delay off if desired.
Old 08-30-2015, 11:56 AM   #6
Got Smoke?
Got Smoke?'s Avatar
Question, will this work on a 87 model truck that's been swapped to a carb'd motor? My brother bought a 87 C10 that was originally a tbi/manual and now its a carb/th350, and none of the gauges work and I can't find the wiring that goes to them in the engine compartment.
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 08-30-2015, 05:30 PM   #7
gmachinz
The 87's have a different firewall bulkhead but if you need an 87 bulkhead wired for a carb setup I can provide you with one! PM me your info as I have several questions aboutbyour setup before I can quote you a price. Thanks!
Old 08-30-2015, 05:56 PM   #8
TravisMartin
Curmudgeon of Poor Means
Glad to see you're doing this! As the weather cools off I'm getting ready to get back on to my '78 retrofitted with a '95 TBI 454/4L80E and I'm going to need a custom engine harness.
Can you make a dual tank option harness? Since I'm going TBI I'd like to change mine in to an '87 setup.
I want to see you make money on it so you'll still be doing it when I need it.
TravisMartin is offline   Reply With Quote
Old 08-30-2015, 09:08 PM   #9
gmachinz
Yep-no problem...just let me know when you're ready for a conversion engine harness. As for tank harnesses, I have single and dual tank harnesses available for the rocker type setup-and there are a few different options.
Old 09-01-2015, 06:05 AM   #10
DarkKnight
How does this compare to OEM, or painless wiring?
Does this go back to the fuel tanks too?
Thanks. Dollar saved is a dollar earned.
86 Chevy Silverado
2012 Silverado CC
2015 GMC Sierra 2500 Duramax
DarkKnight is offline   Reply With Quote
Old 09-01-2015, 09:16 AM   #11
gmachinz
I'm not aware of anyone else offering factory style truck engine harnesses-I include the correct style of terminal for use with your stock 12V firewall junction which is actually the main feed for the AC relay. I include the correctly sized fusible links, correct washer motor/pump leads (and knowing some use 84-87 fenders on 81-83 trucks for example) where the pump mounts either in the housing or in the washer jug. I upgrade charging system leads where needed and supply the correct pigtails. I use 257F rated Delphi looming with the correct rosebud clips/breakouts and end clips where needed. And above all that every crimp is dip soldered.
However, knowing everyone may have different needs, its easier to custom build to suit your particular application since very few people have a 100% stock truck.
Old 09-01-2015, 09:59 PM   #12
4X4GMC1972
4X4GMC1972's Avatar
Will you ever make any for an '87 TBI?
1978 Dodge Omni
4X4GMC1972 is offline   Reply With Quote
Old 09-02-2015, 05:28 PM   #13
gmachinz
Yes...I'm actually in the process of organizing and labelling my inventory of TBI specific parts to make them.....as well as designing new schematics for both the 350 and 454 TBI harnesses. I've been busy keeping up with orders and a lot of them lately have been custom harness builds so its always a time thing to get new harness designs out.
Old 09-02-2015, 09:46 PM   #14
4X4GMC1972
4X4GMC1972's Avatar
I have two 1987's with a 305 manual trans. that will probably need them.
1978 Dodge Omni
Old 09-22-2015, 02:12 AM   #15
84lngbed
I'll take one of the harness. How much more for the HD 4ga charge system upgrade?
84lngbed is offline   Reply With Quote
Old 09-22-2015, 06:44 AM   #16
gmachinz
PM sent!
Old 10-06-2015, 12:29 AM   #17
gmachinz
Here is another custom engine harness kit going out tonight for Brandon! This is your 1990 crew cab harness for an old school carbed 454 sir! This harness is setup for HEI, aftermarket carb choke thru oil switch circuit, gauges, sealed fuse protection for external electric fuel pump via relay trigger, OEM wiper leads and all terminated in a correct 1987-up style C100 bulkhead!
If anybody needs a custom harness, drop me a line and see what options I can set you up with!!
Old 10-06-2015, 12:30 AM   #18
gmachinz
Your engine harness kit is due to ship out by Wenesday !! I'll post an update when its ready!!
Old 10-06-2015, 03:13 PM   #19
zaccaglin
zaccaglin's Avatar
Would be interested in a 6.2l diesel harness if you could make it for my 85 with charging upgrade.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 10-06-2015, 07:30 PM   #20
gmachinz
Is your truck a factory diesel or are you dong a conversion? I can supply you with an engine harness either way!
Old 10-08-2015, 10:29 PM   #21
zaccaglin
zaccaglin's Avatar
Factory truck with a 6.2l from the factory. Just want to clean up under the hood. I would need an estimate before i lock down on it tho.
Zaccaglin
Former Rig:
Old 10-14-2015, 06:06 PM   #22
84lngbed
Any updates?
Old 10-14-2015, 06:33 PM   #23
gmachinz
Lol....that is nice timing....I'm taking quite a few orders out tonight to ship via USPS. I'll get ya tracking here in a little bit!
