04-05-2016, 07:33 AM | #1 |
Where to put the battery
I am building a 46 pickup and I can't decide where to put the battery. Not much room under the hood. Any ideas? I like to see some pics if you have some.
46 Chevy Pickup (project) 60 Chevy Biscayne 93 Caprice wagon(Impala SS style) 99 Corvette convertible 2014 Silverado 2500HD 92 Chevy 1500 (Shop/plow truck) 02 Silverwing 05 H-D Springer Classic 2011 Civic (Wifes car) 03 Highlander (beater) 96 Honda Elite 80 |
04-05-2016, 08:08 AM | #2 |
Re: Where to put the battery
I run a 67 tray bottom -- with modified supports on this 42. If I put a heater core in it -- which I really have no reason --- I would have to put the radiator hose connections lower than stock. I do need to lay the alt out a little to get rid of a startup squeal and yes my master cylinder has a slight cant to it -- not planned. On right side of battery --brace goes down.
My 46 which has the 1954 235 inline 6 will remain under the floor. Last edited by dennislbrooks; 04-05-2016 at 08:39 AM. Reason: words |
04-16-2016, 11:53 PM | #3 |
Sorry to highjack...Dennis I see a concern in the photo you posted & thought I'd bring it to your attention incase my thinking turns out correct, you'll know right where to look. What I'm seeing is the lack of wrap on your waterpump. That "skimming" off of the side of the pulley like that will likely not run the pump under load. Lorne
04-17-2016, 06:41 PM | #4 |
That mount and arm came from speedway. Since then I have laid the alternator more toward the passenger side ande redid the arm --added 3 inches to the belt.
thanks
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
04-17-2016, 06:58 PM | #5 | |
Chevy guy
I ran into the same problem/worry with the belt on the water pump and what I did was find a double grove water pump pulley and looped the power steering belt over the water pump so both belts run it. Jon
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
04-05-2016, 09:46 AM | #6 |
On my 40 I put the battery under the truck by building a battery box that bolts to the frame rail and drops down when I need to change the battery. On my 39 I am going to build a bracket and box to mount it under the front fender like I did on my 41 coupe. I don't care much for looking at a battery under the hood.
04-05-2016, 05:36 PM | #7 |
Mines going in the bed of the truck inside an old Coke cooler I found at an antique shop.
04-05-2016, 06:02 PM | #8 |
04-05-2016, 08:18 PM | #9 |
04-06-2016, 08:58 AM | #10 |
04-06-2016, 03:28 AM | #11 |
True that ^
04-18-2016, 01:18 PM | #12 |
http://67-72chevytrucks.com/vboard/s...518308&page=16
Under the floor, since you should only need to hook a trickle charger to it in the future and that's where it was to begin with right
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
