Old 05-10-2017, 05:49 PM   #1
57taskforce
All about them K’s
57taskforce's Avatar
Ord steering box frame repair 67-72
Any body have pictures of the ord frame plate kit on a 67-72? I got the kit in the mail today to fix the cracks in my frame and it doesn't fit worth a crap. I know it's intended for a square body but the site says it will work with the 67-72 trucks as well. It's gonna take a lot of work to get the lower plate right and the bottom rear corner of the side plate is way off too. Post up what you got! Thanks!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 05-10-2017, 07:43 PM   #2
jeffahart
jeffahart's Avatar
Re: Ord steering box frame repair 67-72
I had a link to this article. I considered one last time my box was out. But I never pulled the trigger because I have not actually seen a crack. Hope someone can chime in for you.
https://ck5.com/forums/resources/ord...repair-kit.62/
White K20
jeffahart is offline   Reply With Quote
Old 05-10-2017, 10:52 PM   #3
jjzepplin
jjzepplin's Avatar
I put one on mine a long time ago. No big wup. Just cut to fit. A little opening up of one of the holes near a rivet if I remember right. No pics as it is assembled now.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-11-2017, 09:11 AM   #4
57taskforce
All about them K’s
Jeff that link was helpful for seeing how it's intended to be installed. I was curious how the bottom and the side plate welded together. That helped clear it up.
JJ- That's about what I figured. I just wanted to make sure I wasn't missing anything, because everything is way different on the bottom plate. I'll fire the plasma up and do some trimming...
Tyler
Old 05-11-2017, 09:37 AM   #5
jjzepplin
jjzepplin's Avatar
There is also one that goes between the frame rails and connect to the rear side of the steering box. That one looks to be quite strong as well. Both together would prove to be very unlikely to have a failure. Although I have been pleased with just the plate unit. My frame started out with no cracks. I then totaled the truck bending the frame and front springs. Still no cracks at the plate. Cut it off and installed it on my other truck. SOlid performance.
