02-03-2017, 08:40 PM | #1 |
Who makes a good quality OEM performance clutch kit?
When my truck came apart it had an 11" clutch. The disk actually looked fine, but the pressure plate had a few bent diaphragm fingers, so at least the pressure plate needs to be replaced.
I'd like to get a good stock clutch. Not anything fancy for racing, but I'd like to find something of equivalent quality that GM might have installed in a stock '70 Corvette or Z-28 Camaro with an LT-1. I went to RockAuto to look for clutch kits and I saw them anywhere from $35 to $170. For brands like "Brute Power," "M-Pact," and "AMS Automotive." I have never heard of these brands. I usually prefer AC Delco to "keep my GM car all GM," but Rock didn't list them. Does anyone have recommendations for 11" clutch/pressure plate kits?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
02-03-2017, 09:16 PM | #2 |
Re: Who makes a good quality OEM performance clutch kit?
I would go with the zoom clutch kits from summit racing.
1973 Chevrolet C10 Stepside 454 |
02-04-2017, 12:27 AM | #3 |
60-66 Nut
It's been a long time since I have bought a clutch but Luk clutches used to be one of the best.
02-04-2017, 09:10 AM | #4 |
Luk clutchs ac delco center force, stay away from zoom or perfection clutchs zooms made by perfection i tried both in my c10 and both went south after couple thousand miles the ac delco had over 15k on it when i pulled for an automatic swap and still looked new guy i sold it too has over 45k on it so far still doing good im told
02-04-2017, 09:30 AM | #5 |
Speedway motors has some good prices on clutches. I was shopping for my Camaro and didn't pull the trigger yet but leaning toward saving money at Speedway.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-04-2017, 02:14 PM | #6 | ||
"I ain't nobody, dork."
Centerforce... period. Best clutches made.
Gary
02-05-2017, 01:42 PM | #7 | |
Unless you do a lot of speed shifting and clutch slipping, I'd get a stock replacement kit, or maybe one step up. I say that because I once used a street/strip kit from RAM, but it took a lot of force to push in the pedal, and it was a little too "grabby" on release.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-09-2017, 06:04 AM | #8 |
I like the Centerforce II's. Have one in my '68 C/10 L6 292 and had one in my '71 GMC Jimmy w/V8 350.
02-10-2017, 06:49 PM | #9 |
I am going to need one in my 68 6 Cyl. I want a easy to push but reliable. The one in there now pressure plate going bad. Not sure what brand it is. Which AC Delco one would be best?
Sorry if I hijacked. Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
02-10-2017, 08:17 PM | #10 | |
They are American-made.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-10-2017 at 08:26 PM. |
02-15-2017, 07:45 PM | #11 |
Fabricate till you "puke"
I also ran a Center Force clutch set up....good stuff, & easy peddle , as orange stated Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-19-2017, 12:19 AM | #12 | |
https://www.youtube.com/watch?v=f7AjwdIWh4c
02-19-2017, 11:05 AM | #13 |
Nice Video, Thanks.
Ron
Tags |
clutch, corvette, lt-1, z-28 |
