05-20-2019, 02:08 PM | #1 |
Never Ending Projects
Solution for 1 speed wiper switch
Since it seems that I was unable to find anyone making a 1 speed wiper switch (2 speeds ones are available) I was able to "make" one that works just like the original.
Buy a 1 speed wiper switch for a '65 Chevy Chevelle. When you compare it to an original one, they are identical other than for the longer shaft. I took measurements from my original switch and used a Dremel cutoff wheel to trim it down. Then I took the wheel and after marking, I cut a groove to replicate the original one, to hold the knob. It mounts just like the stock one and has the same wire connection. Works great! Hope this helps someone.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-20-2019, 03:41 PM | #2 |
Re: Solution for 1 speed wiper switch
Good to see this type of info. You never know when someone will be alongside the rd with no lights and need this tip.
05-20-2019, 10:22 PM | #3 |
Improvise !! Great job !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
05-21-2019, 10:39 AM | #4 |
Thanks for sharing this!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
05-21-2019, 01:58 PM | #5 |
does the set screw fit in the groove?
1961 chevy K10 my build is------------61K10 build |
05-21-2019, 06:45 PM | #6 |
What set screw? My factory wiper knob had little spring clips inside that grab the groove.
05-22-2019, 02:25 PM | #7 |
My 61 has a set screw on the knob. Maybe changed when they changed the knob style?
