Old 04-21-2017, 11:01 AM   #1
jcramsey
jcramsey's Avatar
T5 spacer option
Been looking for a spacer to bolt my T5 to my 250 and ran across this one. All I've seen before were the 1/2" thick aluminum ones. This one is 9 ga steel plate (.1495") . Says you have to cut an inch or so off the bearing retainer collar and maybe 1/8 inch off the input shaft. The price is right. Looks like he's sold a good bit of them and no negative feedback so it seems legit.
Thoughts?
https://www.ebay.com/p/?iid=32116849...pp=true&chn=ps
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-21-2017, 02:11 PM   #2
scoot_mcgrute
Re: T5 spacer option
That's essentially what I did, I used 3/16" (0.1875) plate, and I've had no problems or regrets with it.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 04-21-2017, 02:32 PM   #3
jcramsey
jcramsey's Avatar
Thanks...that's what I like to hear!
The Egg Hauler
The Government Mule
Old 04-21-2017, 06:34 PM   #4
jocko
jocko's Avatar
Hmm. That seems like an awfully skinny spacer - good datat point that a slightly thicker one worked for scoot. Here's how I did it, but I used a 1/2" plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=482069
Old 04-21-2017, 07:22 PM   #5
jcramsey
jcramsey's Avatar
Yea I know, it almost seems to good to be true....but for $35 I'm willing to give it a shot!
I've read your post a lot the last week jocko
The Egg Hauler
The Government Mule
Old 04-21-2017, 09:02 PM   #6
Lugnutz65
Lugnutz65's Avatar
Thoughts?
That should work fine. A spacer is only for an S10 input shaft. The V6 Camaro T5 is 14 spline and the splines are cut further along the input shaft, so it doesn't need a spacer. The V8 will bolt up without any spacer or modification. It's cheaper than a Jeep shaft swap but you'll need to get a 14 spline clutch disc.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-21-2017, 10:37 PM   #7
jcramsey
jcramsey's Avatar
I can't remember if I told you that I picked up an s10 t5 at the auto fair and sold my v8 Camaro trans? The more I thought about it, the more I wanted the s10 tailhousing, and this trans actually goes smoothly through all the gears
The Egg Hauler
The Government Mule
Old 04-22-2017, 09:42 AM   #8
Jgowin
Jgowin's Avatar
Thoughts?
After seeing this I pulled the trigger on one as well, I've got a a T5 I'm wanting to install and for that price it's hard not to. Now all I need to do is figure out which truck to try it on, my 66 or my 51.
Jgowin is offline   Reply With Quote
Old 04-22-2017, 04:58 PM   #9
Lugnutz65
Lugnutz65's Avatar
What 14 spline clutch disc do you guys plan to use?
Here is some info I copied from my website. I hope it helps you.
Clutch Disc Options
1988 Astro van with 4.3L engine clutch disc – 14 spline and 11”
Option 1: M-PACT clutch systems part # 384212 from Rock Auto
Option 2: SACHS BBD4212 from Rock Auto
1984 S10 2.8L V6 uses 9 + 11/16” 14 spline clutch disc
Old 04-22-2017, 06:32 PM   #10
jcramsey
jcramsey's Avatar
If you end up getting yours installed before I do, let me know how it goes!
Clutch Disc Options
I haven't looked at clutches yet, thanks for the info! 11" clutch sounds like a good option.
The Egg Hauler
The Government Mule
Old 04-22-2017, 07:20 PM   #11
scoot_mcgrute
I'm using the Astro Van clutch on mine. Worked great behind the 292 and should work great behind the 5.3 as well.
1966 Army Truck
Old 04-26-2017, 02:58 PM   #12
jcramsey
jcramsey's Avatar
Good info. Thanks Scoot! I love your truck, by the way
Got my spacer in the mail today. looks to be a quality piece. Now I want a cnc plasma setup! Hoping I can get everything put together soon!
The Egg Hauler
The Government Mule
Old 04-28-2017, 12:06 PM   #13
scoot_mcgrute
Right on! You'll love the additional gear on the highway, it's awesome. Thanks for the kind words
1966 Army Truck
Old 04-28-2017, 12:17 PM   #14
sambrutay
sambrutay's Avatar
interested.
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
