Old 10-30-2003, 12:50 AM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Transmission/transfer case question
Ok, I am in the planning/dreaming stage on my project as far as motor and transmission goes. My question is, will different transmissions such as a 700r or the newer overdrive hook up to my transfer case on my 72 Suburban? How about a 5 Speed manual from about a 90 model 4wd Chevy Truck? Just wanting to know so I can start looking.
Scott
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-30-2003, 02:21 AM   #2
1969 GMC
1969 GMC's Avatar
to adapt either the 700r4 or a 5 spd OD tranny to the original np205, you will need a special adapter which = $, but would have good results.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-30-2003, 08:47 AM   #3
Scott Johnson
Junior Member
Where can I find an adapter?
Old 10-30-2003, 11:13 AM   #4
ckhd
ckhd's Avatar
Was it originally auto?
If so, you can get an adapter from AA (It's not really an adapter, it's just an output shaft that lets the 700r4 bolt to the NP205 using your original parts). That's what I did with my 'burb's 700r4 conversion.
I'm not sure what it would take if it was manual, or not a NP205.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-30-2003, 11:14 AM   #5
ckhd
ckhd's Avatar
Oh, to do the output shaft route, the tranny has to be taken apart. I had the shaft put in when I had my tranny built.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 10-30-2003, 04:26 PM   #6
Scott Johnson
Junior Member
It is a manual right now, not sure if it is a np205, but I`ll check tonight.
Old 10-30-2003, 11:19 PM   #7
Scott Johnson
Junior Member
I have a np205 and the current transmission is 3sp manual.
Old 11-03-2003, 10:37 PM   #8
Scott Johnson
Junior Member
ttt
Old 11-04-2003, 10:13 AM   #9
ckhd
ckhd's Avatar
I checed out AA's site and they have adapters that will take just about whatever to whatever. They had adapters to get a NV4500 transmission to hook up to your 10-spline NP205 case, and they had them to get a 700r4 to hook up to it too. Go here to download parts of their catalog:
http://www.advanceadapters.com/catalog/catalog.html
This is the specific part of the catalog that I found the adapter charts in:
http://www.advanceadapters.com/acrobat/gm.pdf
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 11-04-2003, 11:31 PM   #10
Scott Johnson
Junior Member
Thanks ckhd, I`ll check them out.
Old 11-10-2003, 12:11 PM   #11
72beast
TONYP
72beast's Avatar
not sure with your three sp trans...but a 700r will will hook up to the 205 with a TH350/NP205 adapter plate...you can do 1 of 2 things...
(1) buy and install the Advanced Adapter output shaft for the 700R4($185.00), find or buy the adapter TH350/NP205 ($225.00) and it will bolt right up.
(2) find or buy the adapter TH350/NP205 ($225.00), add a 2" spacer ring between the 700R4 and the adapter, cut about 1" off the output shaft of the 700R4..
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
72beast is offline   Reply With Quote
