Old 02-05-2019, 12:12 AM   #1
Hollow65
Hollow65's Avatar
‘92 454 questions
1992 gmc 454 is it worth converting to a 496?
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 02-05-2019, 01:49 PM   #2
bob arrington
Re: ‘92 454 questions
the way I understand it, its a 454 bored 60 over with a stroker crank and rods that can use pump gas. For the money spent on something to drive every day, not something I would do. depends on your intended use
bob arrington is offline   Reply With Quote
Old 02-05-2019, 02:11 PM   #3
DieselSJ
what are you talking about? Is this a 454 equipped truck that you want to drop a 496 into, or do you have a 1992 454 that you want to rebuild into a 496?
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 02-05-2019, 02:19 PM   #4
bob arrington
hmmmm, "converting"
Old 02-05-2019, 02:32 PM   #5
Hollow65
Hollow65's Avatar
Yes sir. Make in to a 496.
Old 02-05-2019, 07:47 PM   #6
YoungPup1977
Seems everyone and their sister takes a sbc 350 and make it a 383. A 454 big block can be made a 496 by purchasing a scat rotating assembly either forged or cast depending how you plan on using it. Either bore block 030 for a 489 or go 060 for the 496 with the crankshaft having a longer stroke. You can use scat/eagle or others. I just mentioned scat because I have had success with forged rotating assemblies produced by scat
YoungPup1977 is offline   Reply With Quote
Old 02-05-2019, 08:26 PM   #7
Hollow65
Hollow65's Avatar
Excellent suggestion on the 489. I plan to put my 8/71 on it and punish it. Thanks to all for the info. I know the block has 4 bolt mains so I’ll give it a shot.
Old 02-05-2019, 09:21 PM   #8
Mike C
Mike C's Avatar
That's most likely a Gen V block. They have specific requirements for head gaskets and no provision for a mechanical fuel pump. So, make sure you can get the head you want and it is compatible on a Gen V.
Make sure you aren't wanting to run a mechanical fuel pump as well. Personally, if I were building I would run a Mark IV 454 or find an L29 donor Vortec 7.4l.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-05-2019, 09:32 PM   #9
Hollow65
Hollow65's Avatar
Dual electric pumps, the heads I’ll get worked. Thanks for the input. The motor is currently in my 92, I plan to use the block and the trans in my 65c10
Old 02-06-2019, 01:33 PM   #10
95 S_Trucker
95 S_Trucker's Avatar
The heads are peanut port. Good for low end torque and nothing else. The intake runner is just to small.
95 S_Trucker is offline   Reply With Quote
Old 02-08-2019, 09:12 PM   #11
Mike C
Mike C's Avatar
Peanut port heads still outflow most cheap aftermarket small block heads. They can be made to make decent power without much TOO much work.
Google "ported peanut port heads" and you will find enough to read for a week.
But I'd start with an L29 which has the hydraulic roller and a pretty darn good set of large oval port heads. You should be able to score one for fairly cheap in a pull-ur-parts type yard.
44 Willys MB
52 M38A1
64 Corvette Coupe
