04-16-2019, 08:59 AM | #1 |
Driveshaft...
Where is the best place to get a new driveshaft for a long bed truck ???
It's been a long time coming... It's time to get it done.. |
04-16-2019, 09:33 AM | #2 |
Re: Driveshaft...
Do you have the old one? Is it a standard duty or Heavy Duty shaft (can tell by the carrier bearing- Light duty bearing has one mounting point, HD has two points)
If you have the HD shaft, you should just rebuild it as long as you don't need a longer one. For the money invested it's the strongest driveshaft you'll find. |
04-16-2019, 10:15 AM | #3 |
Re: Driveshaft...
Any good driveshaft shop can build one or rebuild yours with new bearings and a good balance i kept breaking the carrier bearings on mine last time ti did i took it and had a drive shaft shop go though it was around 100 buxs for new joints carrier brearing and balancing the shaft its been 15k miles not had an issuse since
04-16-2019, 10:29 AM | #4 |
Re: Driveshaft...
I have a bran new aftermarket carrier bearing just sitting in my garage if you need one. I can sell it for 75%.
04-17-2019, 05:33 AM | #5 |
Re: Driveshaft...
I have the two bolt carrier but I also need it to be longer... I can't find any driveshaft shops my area that specialize in making them … I was thinking of ordering one online just have never done that....
